Sun Apr 15, 2012 9:05 pm
Are you from korea? I hear they are fanatical about playing starcraft there. LOL?
just kidding, but you should know there isn't a native Linux version of starcraft, so I wonder what version you want to play, and how?
Not that it matters much.
The R-PI use 5V at an average current of about 400mA (depending on what the CPU and GPU are doing), but really they run off 3.3 Volt, the 5V is only used to power the regulator (for 3.3V) and for the USB devices. But say the average energy consumption is 2 Watt @ 5Volt.
because the header of the post is "battery life", I assume you want to run the R-PI on a battery, well first you have to output of the battery to a useable voltage for the system (actually that mainly means for the USB deices, because the R-PI itself will probably run on something like 3.6Volt fine, but not the keyboard and mouse!
Say you are using NiMH rechargeable batteries, these output 1.2 Volt, so for 5V you would theoretically need 4.166666 batteries, which is a bit difficult, but if you use 4 you would only get 4.8 Volt, which most keyboards wouldn't work with and soon the batteries would drop to say 1.0 Volt, so you need 5. But then you would get 6 Volt when fully loaded, and (again) the keyboard would have a hard time. Also each battery will supply about 2000mA/H Or 2 Ampere for one hour, even when using 5 of them they would be depleted in 5 hours, and you still would need to convert 6 Volt to a steady 5V which is difficult. Instead use 10 of them for 12Volt, and use a "cigarette plug converter" (which are cheap and plentiful), which take 12V or 10V which they convert to 5V at the required amperage (so use one that can supply at least 600mA). These convert the energy with a reasonable efficiency of 70% or more (unless you buy a garbage one with a passive regulator "7805 style" in a TO220 package, do not buy those!) So with ten AA NiMH batteries you could have something like eight hours, just for the R-PI (and maybe keyboard and mouse) alone. The display is another matter entirely.
