Power supply voltage drop...any suggestions?
Posted: Fri Jun 21, 2013 4:22 am
For about two weeks or so, I had my raspberry pi on continuously running xbmc with two network connections (wireless (usb dongle plugged in directly to the pi) and wired). After a while I noticed that I could no longer ssh into the raspberry pi and although when I plugged in the usb keyboard directly it would respond, attempting to do anything involving network would cause it to stop responding on all fronts for a while. It wouldn't respond to pings or anything like that either afterwards.
I suspected the power supply was going bad after I noticed that plugging in my wireless dongle would cause the raspberry pi to reset when previously it did not. I then measured the voltage across the input capacitor with my crappy multimeter and noticed that before the device started it was 5.1V and would hover between 4.7V and 4.8V when active. I think the high current draw from xbmc's idle state (100% cpu...compared to 40-60% when playing an MP4 over the network
) may have caused it to slowly degrade since I believe it was more stable before and didn't drop as much.
So, I am in the market for a power supply that will be more reliable, yet still on the not incredibly expensive side. Does anyone have any suggestions? There are a lot of power supplies out there, so I figured I may as well ask around to see what people here are using.
