Page 1 of 2
Re: Writing to, and backing up SD Card (Using Windows, Alternative Software)
Posted: Sun Apr 15, 2012 8:44 am
by itsonlyme
Yesterday while attempting to write the new Debian image to an SD card (under Windows 7), ready for my Pi's arrival on Monday, I was unable to get "Win32Diskimager" to recognise the card. It had done so previously without problem. Initial thoughts were that the card had gone bad, but then I found that the card could be seen by other software. Computer reboot did not solve the problem.
Looking for clues I found "DiskImage_1_6" which I downloaded and found it wrote the new image to the card without problem. I also saw that DiskImage is able to write the image from your card to another disk. This I did after using GParted to adjust the original partitions. This will be useful later if I need to rewrite or backup a card under Windows.
The only issue I noticed was that DiskImage does not have the facility to verify that an image has been written correctly.
The download link for "DiskImage_1_6" is
http://www.roadkil.net/program.....sk%20Image
Posted: Sun Apr 15, 2012 9:36 am
by Tass
Thanks itsonlyme - looks nice. It'll be especially useful in creating backups of an SD card once I've got my RaspPi OS into a state I'm happy with, including all the drivers, etc.
I had the same issue as you, where Win32DiskImager would intermittenly see the card (I'd say 1 in 20?). I found that the existing content of the card sometimes played a part in it working.
I tried out DD for Windows and while it's a little more manual, I've found it worked every time. I've put togther a post on my blog here that should hopefully provided a step by step guide to creating your SD Card. There are instructions on how to first completely clear the card, then apply any of the images, with the expected results
http://myraspberrypiexperience.....ndows.html
Posted: Sun Apr 15, 2012 5:21 pm
by mahjongg
My guess is that Win32DiskImager cannot handle non windows (i.e. Linux) partitions, and doesn't try to remove these before trying to put an image onto the SD-card. Which may lead to problems with the program, or an invalid card image. I would recommend using a Live linux CD (or DVD) with GPparted (partition editor) to remove any and all partitions on the card before running Win32DiskImager.
Posted: Mon Apr 16, 2012 6:24 am
by markb
I suspect you are correct - I have the same problem trying to upgrade a card with the new Debian image.
Posted: Mon Apr 16, 2012 9:48 am
by jamesh
Not quite sure why that would be. AFAIK, it just dumps the image file over the SD card, whatever is already on it. I've certainly never had problems in that respect.
You could do a format of the whole card prior to doing the imaging.
Posted: Mon Apr 16, 2012 10:15 am
by markb
Not from windows, it can only see a 75MB partition.
Posted: Mon Apr 16, 2012 10:18 am
by Tass
I had the same problem - couldn't format it from inside Windows and couldn't write to it using Wind32DiskImager. I tried using DD and even with that, I couldn't write the image without deleting the partitions first.
The link in my post above has steps to remove the partitions using diskpart. It's a fairly simple process - just look at the disks & partitions carefully to make sure you delete the right ones
Posted: Mon Apr 16, 2012 12:02 pm
by Bad Wolf
To delete partitions on SD cards using windows
Click Control panel > Administive Tools > Computer Management > Storage > Disk Management
Select Disk corresponding to SD card
Right click on Partition you wish to delete and select Delete Volume Simples!
Posted: Mon Apr 16, 2012 12:12 pm
by ukscone
If you've ever used the sd card before and you are going to be writing the disk image under windows i'd recommend using the panasonic sd card formatter just to get everything back to a known state and make sure the whole card is recognised.
https://www.sdcard.org/downloads/formatter_3/
Posted: Mon Apr 16, 2012 12:18 pm
by Dinosaur
Or put the card in a digital camera and format it.
Posted: Mon Apr 16, 2012 12:27 pm
by Gert van Loo
Just as a note: the SD-card slot in my laptop does not work at all with any of the tools. I have to use an external USB <=> SD converter.
by Chris.Rowland
I tried using Win32DiskImager last night and it seems fine, it overwrites whatever is there.
Format in Windows said it was only doing 75 mb but it might actually do the lot.
There's a low level formatter for SD cards:
It seems to be able to format anything you give it, this definitely gets the full disk back.
Ext2Read is a program that will examine a Linux formatted disk in Windows:
http://sourceforge.net/project...../ext2read/
There are a number of others.
All available using Google.
by Tass
Not always so simples...
It wouldn't let me delete the boot partition that way for some reason - the only way I could do it was through DD.
@ukscone, great link - clean, simple process
@Dinosaur - good idea, back to basics!
Posted: Tue Apr 17, 2012 3:28 am
by Guest
Could we see a screen image of what a SD card should look like after a successful image write.
Posted: Tue Apr 17, 2012 4:14 am
by ukscone
hp laptop and/or ricoh builtin reader/writer?
Posted: Tue Apr 17, 2012 7:21 am
by Tass
@woolfe9761 take a look at the link in the 2nd post, I have screenshots of the outcomes of all the images.
Posted: Tue Apr 24, 2012 5:08 pm
by chaddy501
im an absolute beginner looking to find out how to get my sd card ready to go in the board can someone give me a link to software and anything else needed to get me on my way. please remember i am an absolute beginner so as simple as possible please
Posted: Tue Apr 24, 2012 5:40 pm
by Tass
You haven't mentioned your current OS, but if you're using Windows you could try one of these two:
http://myraspberrypiexperience.....-card.html
The first one uses a windows application you can download. The second one, if you're feeling a little more adventurous, used the command line. If you get stuck let us know.
Just one note - they probably refer to outdated links to the images - just make sure you get the latest image
Posted: Wed Apr 25, 2012 3:05 am
by paulemm
EErr, I've got the same problem and my OS is XP SP3 and both the above dont claim to work for XP. Words like "... might have issues" scare me and my pension rigid.
Any solid news for XP users would be VERY welcome.
PM
Posted: Wed Apr 25, 2012 6:07 pm
by chaddy501
tass, hate to say it but still realy confused downloaded that win32 on windows xp but im stuck from there any advice
Posted: Wed Apr 25, 2012 7:42 pm
by Tass
paulemm said:
EErr, I've got the same problem and my OS is XP SP3 and both the above dont claim to work for XP. Words like "… might have issues" scare me and my pension rigid.
PM
I don't have a Win XP machine myself so can't confirm if if will work, but my guess is that the DD option would be an option for you then?
@chaddy501 I think you might have the same issue. DD for Windows is little more complex, but should get you there in the end.
PM me if you guys are still stuck with DD using the link above.
Posted: Wed Apr 25, 2012 8:09 pm
by poing
I had the same issue the other day when I wanted to use a microSD card for Windows again after I had used it in an Android phone. The *very quick* solution was to put it in my Nikon D80 DSLR and press 'format'
Posted: Wed Apr 25, 2012 9:35 pm
by Dendennis
The way to delete the 'boot' partition from an sd card through a windows machine
is with Diskpart,
careful be sure to select the right options or you could
really mess up your system.
windows command prompt -> type "Diskpart"
you will be put into the diskpart utility.
then type "list disk", you'll see disk 0 xxxxMb, Disk 1 xxxxGB disk 2 7.2Mb etc
then type select disk x where x is the number of your sdcard
(i.e. "select disk 2" for the 7.2Mb disk/card)
then type "list partition", this will list all partitions on the selected drive/card
type "select partition x" x being the number of the partition you want
type "delete partition" to delete the selected partition.
then select and delete the remaining partitions.
Posted: Wed Apr 25, 2012 9:54 pm
by Tass
Someone pointed out to me elsewhere that you can use 'clean' rather than manually deleting the partitions individually, but that has even more chance of deleting the wrong partitions then
It would be:
diskpart
list disk
select disk 1 (where disk 1 was listed as the SD card)
clean
Careful now!
Posted: Wed Apr 25, 2012 10:45 pm
by paulemm
Just reporting back that:
1) Win32DiskImager works just fine on my Win XP SP3 netbook and wrote something that took about 3 mins at 10 MB/Sec to a 4GB card. I guess it's OK but I cant read it from Windows. This leads me to my next question:
2) Is there any way to read the disk from windows XP to verify it, as Win32DiskImager does not seem to have a "Verify" function. I suppose I could try copying it back as an image file to another folder with Win32DiskImager. Should that work OK?
I just want to be as ready as I can for the day my Pi gets here and having a good OS on the SD card seems pretty important at present ...
Thanks again
PM
