IgorGanapolsky
Re: Using dd to backup a PI SD
Thu Dec 01, 2016 4:20 pm
kalehrl wrote:Something like this:
Then:
sudo dd bs=4M if=/dev/sdb | gzip > /home/your_username/image`date +%d%m%y`.gz
What does bs=4M mean?
Thu Dec 01, 2016 4:44 pm
It means read a 4MB (4,194,304byte) block on every read, so that reduces the number of I/O operations that need to be completed to copy the card.
I normally look at how much free memory I've got on the machine and allocate 90% of it to a dd copy (that can be anything up to 200M).
B.Goode
Thu Dec 01, 2016 4:50 pm
If @Dougie had not been around to answer your query promptly you could have got the information from a site like this: https://linux.die.net/man/1/dd
Or by typing
man dd
at the shell (command line) prompt of any Linux system.
rpdom
Thu Dec 01, 2016 9:07 pm
Further to the above replies, SD cards often work in "pages" of memory of 4MB. Writing data in that size blocks may lead to better write performance and less wear on the card. Writing to smaller blocks can mean that the card has to read the 4MB page into an internal buffer, erase the original page, and write it back out again with the changes. Then it has to do rewrite the same page with the next bit that has changed.
It cant just erase and re-write part of a page, it has to be the whole thing. (It may cache the changes for a period of time or until it has a whole page of writes stored. Flash storage controllers are much smarter than they used to be).
jogl
Sun Jan 08, 2017 8:12 pm
For what it is worth, I followed kalehrl's original instructions and was able to make a working clone (so far, time will tell).
Old Gateway desktop (AMD processor) running Jessie with XFCE desktop).
EricK-NL
Fri May 12, 2017 8:34 am
Is it possible to install SD-Card-Copier in Jessie-lite?
I don't need all the features of the full Rabian
so wanted to add this handy feature but cant find any links...
Eric
Fri May 12, 2017 8:49 am
EricK-NL wrote:Is it possible to install SD-Card-Copier in Jessie-lite?
Eric
Pi-Clone SD Card Copier is a GUI Program, maybe take a look at RPi-Clone instead ??
https://github.com/billw2/rpi-clone
Thinking outside the box is better than burying your head in the sand...
Return to “Beginners”
