erikcf
Re: raspi-config.....Advanced optios.......
Sat Jun 08, 2013 4:34 pm
It is a name for the system, which can contain letters, numbers, and hyphens (though hyphens shouldn't be at the beginning or end).
klricks
Sat Jun 08, 2013 11:00 pm
The default hostname is: raspberrypi and has nothing to do with the IP address.
You can change it or leave it as it is.
You see the hostname at the command prompt when you start a terminal session.
Looks like this:
[email protected] ~ $
I have 2 RPi's in use, so I changed the hostname on one of them so when I am connected remotely, I don't forget which one I am logged into.
