West-wot
How to mount a NAS drive (smb) to pi
Thu May 30, 2013 10:03 pm
Hi all, basically i am making my pi into a mini torrent server, but want them to stream the files straight to my nas, that is running smb, on 192.168.1.3
how can i mount this ? i have found how to mount usb drives etc but nothing on this
thanks
bucker
Re: How to mount a NAS drive (smb) to pi
Fri May 31, 2013 12:18 am
your NAS is straight attached to your Pi?
if so, sudo mount -t auto /dev/yourNAShere /media/yoursharedfolder
then you go to /etc/smb.con and add the path you mounted
hope it helps you,
cheers
Winning is for losers.
Pi Zero W (inside a Pikachu case ;) ) with DietPi running Sonarr,Couchpotato,Pi-hole,Pi-VPN
Pi B running Home Assistant
Pi 2B & HiFiBerry DAC+ running Volumio OS
Pi 3B (inside a genesis case 8-) ) running RetroPie
