marcelp1
Zip - specifying source files directory
Fri May 17, 2013 8:30 am
HI all,
from current dir so lets say /home/pi/
I want to zip the whole dir in /home/pi/share/FSD/20130516
into /var/www/
with the name FSD_20130516.zip
pi@RaspberryPi ~ $
zip -rT /var/www/FSD_20130516 /home/pi/share/FSD/20130516
that would make the FSD_20130516.zip in the /var/www/ dir as I want it,
but the ZIP files included folders /home/pi/share/FSD/20130516 as well :(
Is there a way to specify source directory for the zip file?
man zip does not have the info :(
SirLagz
Re: Zip - specifying source files directory
Fri May 17, 2013 8:35 am
Not at home at the moment so I'm just Guessin, but try this
    zip -rT /var/www/FSD_20130516 /home/pi/share/FSD/20130516/*
marcelp1
Fri May 17, 2013 8:47 am
Nope Same result :(
fbutler
Fri May 17, 2013 8:54 am
marcelp1 wrote:Nope Same result :(
I haven't used zip in a long time, but have you tried?:
cd /home/pi/share/FSD/20130516/
zip -rT /var/www/FSD_20130516 *
marcelp1
Fri May 17, 2013 8:59 am
Hi that works as well , thank you for that.
I have found what I needed. I should have read the man zip properly rather than looking for the key worlds (specify, source :(
-j
Store just the name of a saved file (junk the path), and do not store directory names. By default, zip will store the full path (relative to the current path).
so this one works now
zip -rjT /var/www/FSD_20130516 /home/pi/share/FSD/20130516
lesson learned.
sprinkmeier
Fri May 17, 2013 10:32 am
zip doesn't know about unix file permissions.
Chances are that if/when you restore the files they'll all be marked executable, or group writeable or somesuch.
I recommend using tar:
tar --create --gzip --file /var/www/FSD_20130516.tar.gz --directory /home/pi/share/FSD ./20130516
or
tar --create --gzip --file /var/www/FSD_20130516.tar.gz --directory /home/pi/share/FSD/20130516 .
(the first one is more unix-y; un-taring the file puts everything in a subdirectory rather than polluting the current directory. neatness counts!)
If you need to read the files on a legacy PC get 7Zip
http://www.7-zip.org/
marcelp1
Fri May 17, 2013 10:55 am
sprinkmeier wrote:zip doesn't know about unix file permissions.
or
Thank you for your reply, would user with Win XP Pro OS machine be able to open that file if he has no other compression/decompression software installed be default?
I went for the .zip as I know Windows can open .zip files ....and its just *.jpg files inside anyway.
Joe Schmoe
Fri May 17, 2013 10:58 am
Yeah, I wouldn't worry about it. For what you are doing (where Windows compatibility is the issue, not arcane issues with Unix file permissions and such), ZIP is fine (and preferred).
sprinkmeier
Fri May 17, 2013 11:28 am
marcelp1 wrote: Thank you for your reply, would user with Win XP Pro OS machine be able to open that file if he has no other compression/decompression software installed be default?
Probably not, Windows has a reputation for not playing well with others or sharing its toys :-)
(no hard feelings, us archane unix folk prefer our own toys anyway)
You could set up an FTP, WebDAV or Samba server on the RasPi, this should allow windows to browse /home/pi/share/FSD/20130516 and select files individually rather than having to zip and download the whole directory.
