spleen387
Re: RasTrack added to raspi-config
Thu May 16, 2013 7:59 pm
to get more people to use it.....
cyrano
Thu May 16, 2013 8:02 pm
It's not even showing any Pi's right now...
ryanteck
Thu May 16, 2013 8:35 pm
Hi There, Ryan Here.
The reason why is because It was suggested by quite a few users, I spoke to Alex about it and it was Semi agreed.
Full details are being announced this weekend.
Currently from where some have been added and it hit the 20k mark the programming has caused a few errors, darn my 15 year old coding?
Hopefully I can fully talk about it soon.
Thanks - Ryan
cyrano
Thu May 16, 2013 9:43 pm
So, put it in place first, announce it later. Seems odd to me.
DirkS
Thu May 16, 2013 9:46 pm
cyrano wrote:It's not even showing any Pi's right now...
You mean on the Rastrack website? Checked it earlier today and there were 20+ thousand...
Gr.
Dirk.
DirkS
Thu May 16, 2013 9:52 pm
cyrano wrote:So, put it in place first, announce it later. Seems odd to me.
Can't really see the issue here. A menu has changed... so what?
[NL]Van een mug een olifant maken, misschien?[/NL]
Gr.
Dirk.
ryanteck
Fri May 17, 2013 5:54 am
Responses To Posts:
I can't help the website mucking up, its been in place for almost 1 year now. The Actual addition via the config tool is fully in place as well.
And that's why are we are announcing it tomorrow / sunday
Gr.
Dirk.
Yup, hit the 20k mark on Tuesday I think,
ryanteck
Fri May 17, 2013 2:36 pm
Unlike the full website edition this actually provides a lot more privacy with it only using GEOip and getting your home town. Like the tool says its a bit of fun ;)#
Also the sites up now, :)
ryanteck
Fri May 17, 2013 3:58 pm
If you find the Github repo (https://github.com/asb/raspi-config and create an issue for Wi-Fi someone may look into it, I may even look into it for you :)
ukscone
Fri May 17, 2013 11:44 pm
ryanteck wrote:If you find the Github repo (https://github.com/asb/raspi-config and create an issue for Wi-Fi someone may look into it, I may even look into it for you :)
it's not been maintained for yonks but this would do as a base for wifi setup in raspi-config
https://github.com/ukscone/ZipitZ2/blob ... c-z2sid.sh
ErFillion
Mon May 27, 2013 2:03 am
Rastrack seem to be down again! It give me this error (Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (111)) so yeah, just to let you know. Well it was fun to play with it when it was up!
ryanteck
Sat Jun 08, 2013 4:12 pm
You should see a little Raspberry show up on Rastrack.co.uk at your approximate location (Around where your town name is.
It seems to be working fine now.
ryanteck
Sat Jun 08, 2013 4:19 pm
Er?
That was it?
