X Starts Automatically
Posted: Fri Apr 26, 2013 11:36 pm
by telepete
I'm not completely new to linux but I'm sure this has a very simple solution so I'll post here. My Pi is currently running Bodhi (Raspbian with E17). Regardless of my request (to raspi-config) to NOT start x at boot, it starts anyway. If I log out and try to get to a command line, X launches again instantly and I end up in E17 again. Googling around I was only able to find solutions to the opposite problem. How can I prevent X from starting at boot?
Thanks for reading.
Re: X Starts Automatically
Posted: Tue May 07, 2013 1:45 pm
by DaveDriesen
Bodhi boots to a graphical login by default (I believe it is lxdm)
When a system is set up in this way, it will boot to X regardless of what you've set in raspi-config.
See if there's an init script you can disable in /etc/init.d (chmod -x) or to put it another way, find out what the graphical login is, then disable it.
Dave Driesen
Linux dev and oldskool elite
Posted: Tue May 07, 2013 2:17 pm
by GoodGuy98
I believe Bodhi boots into the Enlightment Windows Manager unless they changed for the ARM platform.
http://www.bodhilinux.com/e17guide/e17guideEN/
Posted: Tue May 07, 2013 4:19 pm
by DaveDriesen
True, so you might also want to look for nodm and disable that.
Looks like they came a long way btw!
Dave Driesen
Posted: Wed May 08, 2013 4:50 am
by telepete
Thank you both for your replies. It is indeed E17 enlightenment. I'll give those suggestions a try when I get home.
