External HDD works but will it fry something?
Posted: Mon Apr 08, 2013 1:32 pm
Hi there,
Im new here and new to RPi etc., but have set mine up with xbmc and OPENelec no problems. However, I would really appreciate some help with the following:
I plugged my external portable Western Digitial 1TB HDD into the USB of the RPi and its works fine. The HDD does not have its own power supply. I am worried though that it might be damaging the RPi as it may be getting too hot or drawing too much power. I have read that powered USB hubs should be used to get external HDD's to work. However mine is already working, so do I need an external USB hub to stop it damaging the RPi, or catching on fire on something? Or am I good to carry on as I am. I want to leave the RPI and HDD turned on all the time and at the moment the above is concerning me somewhat.
I did have an issue before when my wireless mouse was plugged into the other USB port at the same time as the HDD and it was causing the RPi to reboot. I dont use the mouse now anyway so the RPi only has an HDMI cable connected and the external HDD. Its working fine again now only the USB HDD and HDMI is connected, but the mouse must have 'tipped it over the edge'.
I dont like to ank questions that have already been asked a million times, but I dont seem to be able to find an answer to the "is it ok to have an external HDD connected directly to the RPI, if it all works, in terms of power, heat and house-fires
". Do I need a USB hub regardless?
I did see the following on this forum:
"by mahjongg ยป Sun Feb 24, 2013 3:05 am
the PI has a polyfuse rated at about 1.1A, for everything! As the PI itself can use about 400 to 500 mA (depending on what it is doing), and you want to be well below the tripping point of the polyfuse, this leaves only a few hundred milliamps for the USB port, not enough for something as power hungry as an USB hard-disk."
So I assume that my HDD is not very hungry and must be using around 500mA as it still works, but am I "well below the tripping point of the polyfuse"?? It all works whether the hard-disk is spinning or not.
I watched a film via it last night and left it switched on overnight and its been on all day, and hasn't rebooted ot anything
Am I worrying about nothing, or will it overheat and wear the harddrive or RPi prematurely?
Any advice would be really appreciated!
Thanks in advance.
Kam
Thanks in advance.
Kam
