Jonathans7
Problem downloading and flashing
Fri Apr 05, 2013 1:16 pm
I have downloaded different versions of wheezy and debian and flashed them to my 16 GB SanDisk card.
All seems to go well. When I insert into the Pi and turn it on nothing happens. The redlight comes on and a green light flashes but that is about it.
I have used the checksum program using SHA and the codes never match.
What am I doing wrong?
samuelt619
Re: Problem downloading and flashing
Tue Apr 09, 2013 6:21 am
This just happened to me too, after an update.
What would you accomplish today if you weren't afraid?
Tue Apr 09, 2013 6:51 am
Jonathans7 wrote:I have downloaded different versions of wheezy and debian and flashed them to my 16 GB SanDisk card.
Does it flash in a steady pattern (if so, how many flashes between pauses?), or just flicker for a bit, then stop?
Did you checksum the downloaded zip file, or the unzipped img file?
Also, check here for common problems: http://elinux.org/R-Pi_Troubleshooting
Tue Apr 09, 2013 6:52 am
samuelt619 wrote:This just happened to me too, after an update.
I suspect that is a different problem to the OP's one.
I see you have started a new thread about it. Good :-)
