Mon Apr 01, 2013 6:25 pm
joan wrote:
I'd like to know how it would harm the Pi. It would be nice to know which part of the Pi is going to blow up first if the voltage rises above 5.25V (especially because mine don't) and at what voltage this will happen.
Hi Joan,
Without looking at the Pi's schematics in detail (IIRC they may be found in the wiki) I can only comment on what I can see on the board. The earliest components in the power chain are the filter capacitor and 3.3V regulator adjacent to the micro-usb power input socket. Having looked at the specs. for t.i.'s version of the "17-33G" 3.3V LDO, whilst that does have thermal overload protection and may be "fed" from voltages higher than 5.25V, there is minimal heatsinking and were the Pi + attached USB/GPIO devices to draw the full 1000mA of recommended PSU's it would be having to dissipate nearly 2W at 5.25V. Also it has been suggested in other posts elsewhere on the forum that the Pi has (what I would call) a "crowbar" device to protect against "overvoltage spikes". At what voltage threshold that may act I don't know. However, if I understand matters correctly, the 5.25V "limit" is also specified to ensure that other connected devices/i.c.'s (USB/GPIO) are not subject to "fatal stresses". I'm sure other forum members could elaborate further. W.r.t. the capacitor I haven't checked its specs but my Pibow model A case carries a "magic blue smoke" warning around it
Trev.
