AlessioMTX
How to overclock the Raspberry Pi with Kali Linux?
Fri Mar 29, 2013 11:22 pm
I've just installed Kali Linux on my SD card that I use with Raspberry. This new OS I think is very good, but at the installation I don't have the opportunity to overclock as it is possible with Raspbian so I'd like to try to check differences. How could I do?
pluggy
Re: How to overclock the Raspberry Pi with Kali Linux?
Sat Mar 30, 2013 8:01 pm
Hazarding a guess it will have the standard FAT boot partition, so edit config.txt ?
DirkS
Sat Mar 30, 2013 10:18 pm
pluggy wrote:Hazarding a guess it will have the standard FAT boot partition, so edit config.txt ?
That's what I would think too. See http://elinux.org/RPiconfig#Overclocking for more info.
Gr.
Dirk.
cyrano
Sun Mar 31, 2013 12:20 pm
config.txt is missing in Kali. You need to install it manually form github. Instructions here:
http://rageweb.info/2013/03/21/raspi-config-in-kali/
DirkS
Sun Mar 31, 2013 12:45 pm
cyrano wrote:config.txt is missing in Kali. You need to install it manually form github. Instructions here:
Are you sure? AFAIK it should still boot from the FAT partition on the SD card and the firmware (which you cannot do without, again AFAIK!) will read the config.txt on that partition...
Your link points to an instruction to install raspi-config which is not needed to change the configs.
Gr.
Dirk.
thedishwasher
Thu Nov 07, 2013 4:31 pm
Correct, you don't need raspi-config. However, there is another post on that site that has info to get your Kali config.txt file created and working correctly: http://rageweb.info/2013/11/07/bootconfig-txt-in-kali/
