/etc/profile startx vs raspi-config
Posted: Sat Mar 23, 2013 3:59 pm
Following some guide I had added startx at the end of /etc/profile to start x automatically.
Now though I had noticed I had a large number of instances of xinit, sh and startx in the task manager and thouth that should be a problem.
After reading you could simpli start lxde through raspi-config, I removed the startx entry at the end of /etc/profile and switched on the raspi-config, reboot. Problem solved.
Why is that? Everything was so slow as a consequence and almost all memory was chugged up in those instances.
Second question, I had manually enabled auto login for the pi login through some other recipe. Was that required in the case where I had enabled lxde to start automatically through raspi-config?
Thanks,
David
Thanks,
David
