I have been running my pi for a month now and it works just as expected. However, most often (but not always) it hangs at the end of installing a new package.
I use wheezy from 2013-02-09. Whenever I want to install a new package I start with "sudo apt-get update" to make sure I am updated.
Just now I installed LibreOffice using "sudo apt-get install libreoffice". The process started as expected asking me to accept the amount of memory needed. So I did and it started to download, unpack etc. Then, after say 20 minutes or so, nothing more happened. From another computer I pinged the pi and connection was lost. Then I rebooted by powering off/on. Then I could see that LibreOffice was actually installed. When I connected using VLC I could start it from the start menu just as expected.
But surely I should not have to reboot after an installation?
LibreOffice is just an example. I also installed Synaptic (had to reboot since connection once again was lost), and with Synaptic I then installed RabbitVCN subversion client. No matter if I use apt-get or Synaptic. Once the installation is finished the connection is lost and I have to manually reboot.
This is particularly irritating since I use my pi remotely, and use ssh or VLC to connect via network cable.
I am not sure but I don't think I had this problem with the earlier wheezy (dec 2012).
Anyone else having this problem?
