arch -powered usb hd not detected
Posted: Tue Mar 12, 2013 2:19 am
Hi all, I just set up my rpi and I hit a bump in the road. I'm running the most up to date arch linux. My rpi is connected to the psu and also a powered usb hub. I have an external HD connected to the USB hub. Unfortunately the device does not show up under /dev/. In fact, I have nothing named sd[a-z] under /dev/ at all. Any assistance would be much appreciated!
Not sure why this is helpful, but I've seen it asked for in other threads:
And the following, in case it helps:
[root@alarmpi /]# lsusb -v | grep -iP "Transfer Type.*(Interrupt|Isochronous)" | wc -l
6
[root@alarmpi /]# grep SCSI /var/log/messages.log | tail -n 5
Jan 1 01:00:07 alarmpi kernel: [ 1.831965] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
Jan 1 01:00:07 alarmpi kernel: [ 1.880565] Loading iSCSI transport class v2.0-870.
Jan 1 01:00:07 alarmpi kernel: [ 1.613062] SCSI subsystem initialized
Jan 1 01:00:07 alarmpi kernel: [ 1.832014] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
Jan 1 01:00:07 alarmpi kernel: [ 1.913045] Loading iSCSI transport class v2.0-870.
[root@alarmpi /]# dmesg | tail -n 5
[ 1096.777641] 0 pages swap cached
[ 1096.777841] smsc95xx 1-1.1:1.0: eth0: kevent 2 may have been dropped
[ 1096.797288] smsc95xx 1-1.1:1.0: eth0: kevent 2 may have been dropped
[ 1124.100966] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 1124.101103] mmc0: DMA IRQ 6 ignored - results were reset
[root@alarmpi /]# dmesg | grep -E "sd[a-z]"
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2708.boardrev=0xe bcm2708.serial=0x2b76f2a8 smsc95xx.macaddr=B8:27:EB:76:F2:A8 sdhci-bcm2708.emmc_clock_freq=100000000 vc-cma-mem=0/0x11800000@0xd400000 mem=0xc400000@0x0 mem=0x11800000@0xd400000 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=noop rootwait
[ 2.334467] sdhci: Secure Digital Host Controller Interface driver
[ 2.334481] sdhci: Copyright(c) Pierre Ossman
[ 2.334588] sdhci: Enable low-latency mode
[ 2.376489] sdhci-pltfm: SDHCI platform and OF driver helper
