Nannerman
Untar a file on a flash drive (solved)
Tue Mar 12, 2013 12:20 am
I'm trying to untar a .tar.gz file on my flash drive. For whatever reason when I right click it, then click the "Extract here" -which is what I would like to do- nothing happens and the CPU meter shows that the PI isn't working on anything.
I try to get to the flash drive through the terminal and I can't go back to the /media directory.
Any thoughts on this?
mahjongg
Re: Untar a file on a flash drive
Tue Mar 12, 2013 12:25 am
maybe you have no rights to write to that volume, try to use sudo.
Nannerman
Tue Mar 12, 2013 12:50 am
mahjongg wrote:maybe you have no rights to write to that volume, try to use sudo.
Thanks for the reply
I think I'm trying to do what you are saying. The problem is, I can't find out how to navigate to the /media/240E-C074 directory in the terminal.
The closest I can get to that is /home/pi
Hopefully that makes sense.
Nannerman
Tue Mar 12, 2013 12:57 am
Okay, I finally found what I was looking for.
What I was trying to ask is how to get to the parent directory past the /pi.
After alot of googling I managed to find the cd .. to get to where I needed.
