torontoraptors
Cannot test sound
Sun Mar 10, 2013 9:30 pm
I am trying to follow the tutorial from the magpi issue 03 to get the sound to work but I can't test it.
I don't have any "Sound & Video" categorie in the menu and I don't know how to install one.
What should I do?
Thanks in advance
Spid
Re: Cannot test sound
Sun Mar 10, 2013 10:18 pm
Shall we guess you have Raspbian "wheezy" installed, then log out so will be at the command line and type the following pressing enter key after each line typed:
sudo modprobe snd_bcm2835
sudo amixer cset numid=3 0
The above will autodetect sound output. Then follow this blog:
http://blog.scphillips.com/2013/01/soun ... -with-alsa
I will always assume you are running Raspbian for desktop and Raspbmc for XMBC !
Return to “Beginners”
