Zone403
Mounting ext4 USB with rw permissions
Fri Mar 01, 2013 2:23 pm
I just got my Raspberry Pi, and have installed Raspbian on it.
Everything's running fine, except that when I connect a ext4 formatted USB drive to it, I can't seem to write files to it. Possibly because the file system is owned by root?
The purpose of this drive is to be permanently used as extended storage (so I want it to mount everytime the system boots).
Is there a way to get the system to get rw permissions on this drive? I prefer to have it formatted as ext4, because I don't have any Windows systems around, and am also not planning to use it on anything else but the RPi.
Any help is really appreciated.
Thanks in advance.
- Jeffrey
lokErik
Re: Mounting ext4 USB with rw permissions
Sat Mar 02, 2013 12:05 am
Well on the mount part I'd say you should look at fstab (/etc/fstab)
I assume it's a already is an topic here for editing it.
Otherwise here is some links for it.
http://www.tuxfiles.org/linuxhelp/fstab.html
http://en.wikipedia.org/wiki/Fstab
While editing it you'd of course need to be root
Cheers Christer
