I'm 99% new to Linux and have been having a hell of a time getting anything to work with my Pi. First it was an inconsistent WiFi while using OpenELEC, then it was setting up Raspbmc which otherwise worked well with my WiFi but had other issues, and then it was discovering that XBMC crashes or reboots the Pi completely after 10 minutes of WiFi media-streaming on either distro (got some vague info about running iperf which I am currently investigating what it is), and then it was a few failed attempts at getting the emulation station/retro-pie installed, and now I'm locked out of SSH because my host key has changed for seemingly no reason (and then I was extremely excited for a case that finally came in, but it's loose fitting and makes me feel like I'll break a port, obviously not the Pi's fault). The first few days I had Bootberry setup (Wheezy and OpenELEC) which ended up being a near complete bust with how many things I was unable to do (things that ended up working without BB).
I am honestly getting depressed that every time I get one thing working I have problems with something else, and so far haven't been able to get a fully working setup after a couple of weeks. My original goal was media streaming and ultimately building a robot army to destroy my enemies (I kid).
I guess I just need some push in the right direction of what I should do for my next format. Should I finally go for Wheezy so I have more potential with adding on things outside of simple XBMC? Is there anything other than XBMC that I could try to accomplish the same thing? Should I cry in the corner?
