mattvenn
blank the screen
Wed Feb 27, 2013 3:26 pm
I'm running with a composite tv on the pi. After boot, I want to wipe the screen of all the messages and the login prompt.
When I play a video, it plays fine, but after it finishes, all the messages and boot prompt are still there.
Any help appreciated!
Matt
-rst-
Re: blank the screen
Wed Feb 27, 2013 3:32 pm
The command 'clear' (http://linux.die.net/man/1/clear) should get rid of most of the stuff...
http://raspberrycompote.blogspot.com/ - Low-level graphics and 'Coding Gold Dust'
mattvenn
Wed Feb 27, 2013 3:53 pm
thanks, but that only works for the screen I type it in.
I need to blank the composite output. I think this is displaying tty1
from /etc/initab:
1:2345:respawn:/sbin/getty --noclear 38400 tty1
I haven't tried removing the getty lines from inittab yet, but it probably wouldn't help with blanking the boot messages.
Cheers,
Matt
mattvenn
Wed Feb 27, 2013 4:44 pm
after messing about with inittab, getty, fim, fbi I found the easy way to blank the screen: write zeros to the frame buffer directly.
dd if=/dev/zero of=/dev/fb0
mattvenn
Wed Feb 27, 2013 4:52 pm
though after the video finishes playing, the old text is still there!
RaTTuS
Contact: Twitter YouTube
Wed Feb 27, 2013 4:58 pm
what are you wanting to do ?
boot up
do
clear
play a video
for ever?
or similar ....
fbset may or may not help
Covfefe
mattvenn
Wed Feb 27, 2013 5:16 pm
I'm wanting to have a blank screen, and when something happens, a video plays. When the video ends, back to blank screen.
I nearly have that, but with short flashes of boot messages in the back ground.
pseudo code:
while forever:
if something happens:
blank screen
play movie
blank screen
The flashes of the boot messages happen between the play movie and blank screen commands I suppose.
I'd rather leave the boot messages there because they're useful for debugging, but I suppose I can configure the pi to keep them quiet.
I'm trying to work out where linux is keeping the contents of the original frame buffer, so I can flush that too. Any ideas?
mattvenn
Wed Feb 27, 2013 5:33 pm
I set the console to be tty2 in /boot/cmdline.txt and that's one way to solve it.
Last thing would be nice to get rid of the flashing cursor!
mattvenn
Wed Feb 27, 2013 5:40 pm
cracked it!
1/- set kernel to log to console 2 (console=tty2 in /boot/cmdline.txt)
2/- wipe screen with dd if=/dev/zero of=/dev/fb0
3/- turn off cursor with setterm -cursor off > /dev/tty1
Then I can play my movie whenever I get the trigger, and have a nice blank screen before and after, no flickers.
Matt
Ruffio
Mon Aug 01, 2016 1:47 pm
So the above instructions blanks the screen with black, but how to do it with other colours? White/blue...
