Werewolf6851
Powered Pi/usb hub insertion
Tue Feb 26, 2013 6:44 am
Greetings all,
With my Raspberry Pi B v2 powered up. When I plug in a none powered usb hub (Either with keyboard and mouse plugged into the hub or not), it will reboot. Wondering if this mostly likely a power issue, or a firmware issue?
Wolf
Lob0426
Re: Powered Pi/usb hub insertion
Tue Feb 26, 2013 6:49 am
That is a common issue with USB devices that draw moderate to high power at insert. Plug it in before you start your RasPi and it should be ok.
512MB version 2.0 as WordPress Server
Motorola Lapdock with Pi2B
Modded Rev 1.0 with pin headers at USB
http://rich1.dyndns.tv/
(RS)Allied ships old stock to reward its Customers for long wait!
Cloudcentric
Tue Feb 26, 2013 8:08 am
It seems best to use a quality Mains Powered Hub, which does not backfeed like cheaper ones have a habit of doing..
I know everything about nothing"
Gustavo_Murta
Tue Feb 26, 2013 11:30 am
Wolf , look my solution for modification of powered usb hub.
I think it may help you.
http://www.raspberrypi.org/phpBB3/viewt ... 44&t=34075
Gustavo Murta
