Question about RP wifi connections
Posted: Thu Feb 21, 2013 4:58 pm
by Loougle
I want to use the Pi in my car and I want to connect my N7 to the Raspberry Pi.
Now what I have read is I must connect the Raspberry Pi through ethernet but is there a way I can connect my Raspberry Pi to a mobile hotspot then use that wifi and connect to the N7?
I am using my Nexus 7 as my car dash unit but I want my 2 monitors in the back seat to connect with the N7. As many know there is no easy way to do this but a Raspberry Pi may work.
I need to use the N7 and use Android Transporter. http://esrlabs.com/android-transporter- ... pberry-pi/
But here it says the Raspberry Pi must be connected to a router, instead of a router can I wifi connect it with a mobile hotspot?
Re: Question about RP wifi connections
Posted: Thu Feb 21, 2013 8:45 pm
by Mobius
The Pi can use a USB wifi adapter. Lots of posts here to search for more info.
Posted: Thu Feb 21, 2013 9:39 pm
by Cloudcentric
You would need 2 WiFi adaptors, one connecting to a WiFi Hotspot, the other to connect the Pi to Nexus 7, there is a good poser !
http://wiki.debian.org/BridgeNetworkConnections
The the Nexus 7 supports Bluetooth maybe the you could use Bluetooth PAN instead of Wifi between the Pi and N7 ?
http://en.wikipedia.org/wiki/Personal_area_network
Good luck !
Posted: Thu Feb 21, 2013 9:44 pm
by tonyhughes
I just enabled WiFi hotspot function on my Samsung Galaxy Note 2, plugged this $9 WiFi dongle https://www.modmypi.com/raspberry-pi-ac ... Fi-dongle) into the Pi, connected to the SSID with the password I set on the phone, and started internetting.
Easy. Fast.
