Hcgrant
Can't get rc.local to run vncserver at boot
Wed Feb 13, 2013 4:23 pm
Hi , Im hoping someone can explain this to me ...
I want to run vncserver at boot so ive added the following to /etc/rc.local ..
# my bit to start the VNC server
/usr/bin/vncserver
date >> /home/pi/vnclocalran # to monitor that rc.local ran and when
# end of my bit
This will execute perfectly from the command prompt and start vncserver.
However for some reason this script wont start vncserver from a cold start (powering up) or from a restart.
I know rc.local is being executed because I can look at the timestamp in the file /home/pi/localvncran
Is there something odd about vncserver that wont let it be started this way?
I have added an "&" after the vncserver command but this doesnt help
I see that there are methods to start vncserver at boot , I havent tried them yet , but I would like to understand why my method isnt working
All suggestions gratefully received ;-)))
DBryant
Re: Can't get rc.local to run vncserver at boot
Wed Feb 13, 2013 4:38 pm
What user do you think will configured to run the server instance you are attempting to start?
From the command line, you're probably the pi-user, from rc.local it will be root. As things stand try running
ps -lef | grep -v grep | grep vnc
which will show vnc processes running on your system (if any).
The other methods you refer to address this issue in a number of ways.
hunternet93
Wed Feb 13, 2013 4:44 pm
In Debian and Debian-based distros, you can set most services to start on boot with the command:
sudo update-rc.d servicename enable
You could try that with your VNC server, I haven't tested but I'm guessing it'll work.
RobinMosedale
Fri Feb 15, 2013 3:33 pm
hunternet93 wrote:In Debian and Debian-based distros, you can set most services to start on boot with the command:
I'm afraid I get error: "cannot find a LSB script for vncserver"
If sudo update.rc.d tightvncserver enable is used, then an error:-
"tightvncserver Default-Start contains no runlevels, aborting
Any ideas?
Robin
Hcgrant
Fri Feb 15, 2013 8:33 pm
Hi DBryiant ..thanks for the reply
Ive checked for the vnc server running after boot with "ps axu" ...its not running.
I wondered if it wont run as root and tried "sudo vncserver" .. that started the vnc server and I can login.
So thats not the problem ... :-(
I'll try the method given in http://www.penguintutor.com/linux/tightvnc and see if that works, if it does I still would like to know why my method doesnt ... I thought rc.local was the place for users to start their own processes at startup
andrum99
Fri Feb 15, 2013 8:47 pm
Hcgrant wrote:Hi , Im hoping someone can explain this to me ...
/usr/bin/vncserver
# end of my bit
I'm assuming you are adding this code before the "exit 0" line? If you don't then your code will never be executed.
Cheers
Andrew.
