valvale97
alsamixer problem
Tue Feb 12, 2013 2:16 pm
hi, i've tried to select my microphone from terminal:
sudo alsamixer
next i close settings pressing "exit"
and i've tryed to save the changes running:
sudo alsactl store
but it doesn't function and alsamixer doesn't save my changes. :evil: :evil:
Please :? , can someone help me ?
scruss
Re: alsamixer problem
Tue Feb 12, 2013 2:45 pm
Do you really need to use sudo? By running it that way, you might be setting the ALSA configuration for the root user, not the regular user.
valvale97
Tue Feb 12, 2013 2:47 pm
i've read in a lot of forums and blog that to save settings you have to use sudo...
Cloudcentric
Tue Feb 12, 2013 2:55 pm
valvale97 wrote:i've read in a lot of forums and blog that to save settings you have to use sudo...
..are you using an USB Sound Card ?
I know everything about nothing"
valvale97
Tue Feb 12, 2013 2:57 pm
no, i'm using a webcam with microphone.
Running alsamixer i can see that the sound card i recognized, but once i've selected i can't save the changes.
valvale97
Tue Feb 12, 2013 4:38 pm
i resolved the problem.
Now when i try to record the voice with:
arecord -d 5 -D plughw:1,0 test.wav
Recording WAVE 'test.wav' : Unsigned 8 bit, Rate 8000 Hz, Mono
and i try to listen what i've recorded using:
aplay test.wav
Playing WAVE 'test.wav' : Unsigned 8 bit, Rate 8000 Hz, Mono
i've a distorted sound, what can i do to improve the sound ?
scruss
Tue Feb 12, 2013 8:37 pm
valvale97 wrote:i've a distorted sound, what can i do to improve the sound ?
Try:
arecord -f cd -d 5 -D plughw:1,0 test.wav
Your first attempt was 8kHz mono 8-bit, which doesn't sound great.
mindmasta
Tue Feb 12, 2013 8:43 pm
It's defaulting to 8-bit, 8000hz mono, but you can make that better (at the expense of a larger wav file, of course). I'm assuming your mic is already in a good location as not to pick up muffled sound to begin with ;)
valvale97
Tue Feb 12, 2013 8:45 pm
i've restarted the raspberry and i don't know why the sound is much better.
If i increment the Hz, will the sound improve ?
Now another question, how can i convert test.wav files to test.flac using python ?
valvale97
Wed Feb 13, 2013 7:30 am
I've tryed this file pranavrc/audio-transcribe/blob/master/speech.py But it gives me an error about this line
fileName = str(sys.argv[1])
texy
Wed Feb 13, 2013 12:04 pm
Did you follow the advice given by scruss ?
Texy
valvale97
Wed Feb 13, 2013 1:27 pm
Yes, But there are no differences. What about the converter wav to flac ?
valvale97
Wed Feb 13, 2013 4:22 pm
when in i run from the terminal:
python speech.py
it gives me this error:
File "speech.py", line 10, in <module>
IndexError: list index out of range
texy
Wed Feb 13, 2013 5:24 pm
Looks like you have to enter the file name of the wav file after speech.py
Texy
valvale97
Sat Mar 02, 2013 3:23 pm
i don't know why sometimes when i run:
it gives me:
overrun!!! (at least 4.547 ms long)
do you know why ?
scruss
Thu Mar 07, 2013 10:09 pm
Have you updated your system and firmware recently? That message is what you'd get all the time with older (say, June 2012) firmwares.
valvale97
Sat Mar 09, 2013 9:01 pm
hi, my crashed and i've to reinstall the OS again.
When i try to roon my old script about the google api i receive this error:
 python speech.py test.wav
Failed to get binary data.
  File "speech.py", line 26, in <module>
    size_of_audio = os.path.getsize(fileName)
  File "/usr/lib/python2.7/genericpath.py", line 49, in getsize
    return os.stat(filename).st_size
OSError: [Errno 2] No such file or directory: 'test.flac'
Any idea ? are 2 days that i spend all my free time to solve this problem...
scruss
Sun Mar 10, 2013 9:41 pm
As I said in my PM, is the file test.flac present on the system?
wally
Tue May 28, 2013 9:28 am
i also want my RPI listen me :)
using speech.py example from
https://github.com/pranavrc/audio-transcribe
..work/audio-transcribe-master>python ./speech.py ./softkitty.wav
Unable to connect
  File "./speech.py", line 43, in <module>
    content = response.read()
NameError: name 'response' is not defined
unable to connect:
used path in speech.py: url = "https://www.google.com/speech-api/v1/re ... lang=en-US"
i assume the applied url is not valid anymore (?)
any ideas ?
thx wally
