hornedfrog
UK power supply in US 110V
Sun Feb 03, 2013 3:21 pm
I have the Raspberry Pi Kit from Maplin and I am setting it up in the US. It has the British plug and power supply. Will it work on 120V US voltage with just a plug-in adapter? Or, will it not get enough current? Thanks.
Re: UK power supply in US 110V
Sun Feb 03, 2013 3:47 pm
Read the spec on the power supply (it'll be written on it somewhere) Check the INPUT settings - usually they can cope with 110 to 240v. If it just says 240v then you should get a new US supply. The current won't be a problem unless it's also a problem in the UK!
redhawk
Sun Feb 03, 2013 4:12 pm
If it's a switch mode power supply then it should be able to handle either 110v or 240v, however always check the label first.
Richard S.
hornedfrog
Sun Feb 03, 2013 4:15 pm
Thanks, will do.
hornedfrog
Fri Oct 18, 2019 8:59 pm
FYI, works fine for 6 years now. Cheers.
Burngate
Sat Oct 19, 2019 9:11 am
Wow!
"Necro"ing old threads, particularly this old, is generally frowned upon, in part because the information can be out of date.
But I don't think that applies here!
There's a lot of people who don't seem to come back and say thank you, so the courtesy is much appreciated.
LTolledo
Sat Oct 19, 2019 9:24 am
Reporting a result after "6 years testing" will surely be welcomed.... :D
Some people be like:
hornedfrog
Sat Oct 19, 2019 12:31 pm
:D it just seems to go and go and go!
Return to “Beginners”
