mpalomer
How can I test SD card speed?
Fri Feb 01, 2013 12:12 am
I want to see how fast my SD card operates on the Raspberry Pi. How do I do this? Also, in your experience, what's the fastest card out there? I'm not doing anything that needs a lot of storage, so anything as low as 4GB would be fine with me.
pluggy
Re: How can I test SD card speed?
Fri Feb 01, 2013 8:57 am
http://elinux.org/RPi_SD_cards#SD_card_performance
On this page is the 'official' way.
Write :
dd if=/dev/zero of=~/test.tmp bs=500K count=1024
Read
dd if=~/test.tmp of=/dev/null bs=500K count=1024
With most operating systems and uses, read speed is far more important than write speed. But you need to run the write test first since it creates a file used in the read test.
I must not tread on too many sacred cows......
Amarand
Contact: Website Yahoo Messenger Facebook YouTube
Thu Apr 30, 2015 9:19 pm
pluggy wrote:http://elinux.org/RPi_SD_cards#SD_card_performance
Write :
Read
It's super important to do this (listed on that link above) after the write and before the read:
sync; echo 3 | sudo tee /proc/sys/vm/drop_caches
If you don't, then you'll hit cache and may see speeds like this:
524288000 bytes (524 MB) copied, 0.998347 s, 525 MB/s
Rather than this:
524288000 bytes (524 MB) copied, 27.8044 s, 18.9 MB/s
Hope that helps!
tonyawad88
Sun Nov 03, 2019 1:44 am
Thank you these scripts helped.
cmoriarty
Tue Apr 21, 2020 2:55 pm
It looks like there is a parameter you can pass to dd "oflag=dsync" to disable caching.
oflag=dsync (oflag=dsync) : Use synchronized I/O for data. Do not skip this option. This option get rid of caching and gives you good and accurate results
source : https://www.cyberciti.biz/faq/howto-lin ... d-command/
Return to “Beginners”
