ValidUser
Autorun a program with root
Wed Jan 30, 2013 7:21 pm
I recently started messing with the Pi with Rasbian Wheezy installed.
I configured freeSWITCH on it in /usr/local/freeswitch and i still need "sudo ./freeswitch" to run it. Is there a way to run this program at start up??? I saw a lot of links on how to do it but none from scratch and none said whether it would run as sudo
Thanks!
Dweeber
Re: Autorun a program with root
Wed Jan 30, 2013 8:39 pm
Many ways... one simple way is to add to the /etc/rc.local file like:
Add you command before the exit 0 that is at the bottom of the script....
# Added freeswitch
/usr/local/freeswitch &
# Original exit 0 at bottom of script
exit 0
This will be run as root when the system boots up. Make sure that the command you are running any anything it might run has a full path to the scripts it needs.
Dweeber A.K.A. Kevin...
My RPI Info Pages including Current Setup - http://rpi.tnet.com
ValidUser
Wed Jan 30, 2013 8:48 pm
again, I am not that good at this yet. What your saying is to go to
/etc/rc.local file
Then add in this text exactly?
I changed it to /usr/local/freeswitch/bin and added the "sudo ./freeswitch" before the exit 0
Is this right???
# Added freeswitch
/usr/local/freeswitch/bin &
sudo ./freeswitch
exit 0
Thanks!!
ValidUser
Wed Jan 30, 2013 8:50 pm
Dweeber wrote:Many ways... one simple way is to add to the /etc/rc.local file like:
# Added freeswitch
exit 0
I probably should have quoted you first!
Thanks again!!
