Gavitor
Password for ROOT account
Sat Jan 26, 2013 4:34 am
HI all,
A simple question. What is the password for the root account
on the RaspberryPi? I'm sick of using 'sudo'.
Any assistance would be appreciated.
ghans
Re: Password for ROOT account
Sat Jan 26, 2013 8:15 am
On Debian , the root account has no password.
If you insist :
sudo passwd root
will set one.
ghans
sdjf
Sun Jan 27, 2013 2:56 am
after installing the sudo package running arch, I can enter the following and it prompts me just once for the root password, and then I am running as root and do not have to use sudo.
su root
I do not know if you can do that with your system, but you could try. It opens another shell with root permission for me, and when I exit, it puts me back in my main login shell.
FORUM TIP: To view someone's posting history, sign in, click on their user name, then on "Search User's Posts." || Running ArchLinuxArm on Model 2B and 512MB Model B
jojopi
Sun Jan 27, 2013 3:29 am
sdjf wrote:after installing the sudo package running arch, I can enter the following and it prompts me just once for the root password, and then I am running as root and do not have to use sudo.
su root
Why did you even install sudo, if you want to use su instead?
The situation in the Foundation's images is not that su does not work, but that the root password is not pre-set. Hence the answer above yours.
You do not actually need a root password if sudo is configured. Then "sudo su" is the same as your command.
DBryant
Sat Feb 02, 2013 7:17 pm
By far the easiest way is to execute:
sudo bash
You will be prompted for your password once adnthen you enter a sheel where you can run as many 'root' commands as you like. When you're done type exit.
The overhead is no greater than enabling the root account.
