zalion0
upgrade vs update
Thu Jan 17, 2013 11:16 am
Just a quick question, whats the difference between apt-get upgrade and apt-get update? :lol:
RaTTuS
Re: upgrade vs update
Thu Jan 17, 2013 11:25 am
update updates the list of servers that can be used
upgrade upgrades the packages
Covfefe
thsBavR10
Thu Jan 17, 2013 11:26 am
there's no difference, just one after another:
- update does synchronice sources (/etc/apt/sources.list) to local package index
- upgrade fetches the new version of installed packages
- dist-upgrade adds inteligent handling od dependencies
(see man apt-get)
sudo apt get update  && sudo apt-get upgrade  && sudo apt-get dist-upgrade
-rst-
Tue Jan 29, 2013 4:05 pm
Afaik, if you will run dist-upgrade, there is no need to run upgrade first:
"In addition to performing the function of upgrade, this option also intelligently handles changing dependencies..." (http://linux.die.net/man/8/apt-get)
So there are two options:
and
sudo apt get update && sudo apt-get dist-upgrade
(that '&&' means 'run the first command until end and if succesful, run the second)
The update is required to be run always: "An update must be performed first so that apt-get knows that new versions of packages are available." (same)
http://raspberrycompote.blogspot.com/ - Low-level graphics and 'Coding Gold Dust'
