I have a question that my speakers with 3.5 mm audio jack and on the raspberry pi 3 there is a audio jack. So is it necessary to buy a converter of hdmi to vga with audio jack ? Or is it ok with a normal converter of hdmi to vga?
Please tell if there will be any problems if i use any converter
which one will you recommend? For a vga monitor (pi 3b+ or pi4)
Regards
Shashwat
- pasdechance
- Contact: Website
Re: I need some help with rsspberry pi 3
If you have external speakers you can plug them into the jack and it should work. You just need to change the audio out options in the OS.
pasdechance
English/French
Debian, Arch, Manjaro, Raspberry Pi OS, LibreElec
English/French
- mahjongg
- Forum Moderator
The analog audio jack does not have enough power to drive (raw) speakers, directly (without an amplifier) the analog output level is intended for earbuds, not speakers.
please read the pictorial buyers guide sticky post in beginners viewtopic.php?f=91&t=83446
The raw speakers have a plug for power and audio jack
And please tell whether i can use a pi 3 or 4 for vga monitor
And if raspberry pi 3 then can i ise a conveter of hdmi to vga without audio jack
And will there any issues ??
- pasdechance
- Contact: Website
So they are computer speakers or bookshelf speakers? It should be OK...but...if you get the adapter that HDMI and audio the quality will be a little better (someone can correct me if I am wrong on that one, I have only ever used the HDMI audio with my pis).Shashwat Gupta wrote: ↑Wed Dec 02, 2020 2:37 pmThe raw speakers have a plug for power and audio jack
pasdechance
English/French
English/French
They are book shelf speakers with a power plug and audio jack
Yes i can buy a hdmi to vga converter with audio jack
Just tell that will there be any issues while i use the raspberry pi 3
Shashwat Gupta wrote: ↑Wed Dec 02, 2020 2:45 pmThey are book shelf speakers with a power plug and audio jack
You can use either type of HDMi - VGA convertors with or without Audio separation:
https://thepihut.com/products/raspberry ... -convertor
https://www.amazon.co.uk/NIAGUOJI-Adapt ... B08DTNZSFP
If you use the on-board Audio Output you need configure for correct output, HDMi is the default:
https://www.raspberrypi.org/documentati ... -config.md
Last edited by fruitoftheloom on Wed Dec 02, 2020 4:00 pm, edited 1 time in total.
The information is out there....you just have to let it in.
My other Linux machines are a ChromeBox & Intel CoreDuo Desktop
Can you explain that how will a vga to hdmi with AUDIO JACK WORK??
Because my speakers have a 3.5mm audio jack and if I buy a converter which has audio in it then how will i connect to my speakers because the aux wire which will be coming with the converter cannot be connected to my speakers as it have A audio jack (which cannot be removed)And a power supply with it
- RaTTuS
- Contact: Twitter YouTube
the PIHut links above will convert the HDMI output of the RPi to VGA and extract the audio strea to the 3.5mm audio jack - you then take an audio to audio lead and plug it from the adapter to your speakers
Covfefe
Covfefe
Shashwat Gupta wrote: ↑Wed Dec 02, 2020 3:52 pmCan you explain that how will a vga to hdmi with AUDIO JACK WORK??
You just plug the Speakers 3.5mm Jack into the Convertor, as above stated the Convertor undertakes the separation of Audio and Video.
So the aux cable which will be provided with the converter have not to be used instead, directly plug the 3.5 mm audio jack into the slot of the HDMI to VGA converter .
Am I right ??
I think this is what you are telling right ?????
Am I right ??
Please tell that am i telling right(in the last message)????
- RaTTuS
which converter have you got ?
post links to everything you have as we cannot see what is on your desk
Covfefe
Covfefe
Shashwat Gupta wrote: ↑Wed Dec 02, 2020 4:19 pmSo the aux cable which will be provided with the converter have not to be used instead, directly plug the 3.5 mm audio jack into the slot of the HDMI to VGA converter .
Am I right ??
Yes
I am buying this converter(attached below)
And i have a audio jack which is attached and cannot be replaced with aux cable(which is image of converter)
And
I wanted to ask that can i directly plug-in the audio jack (into the prot of the converter)(without aux cable which is provided with raspberry pi hdmi to vga converter
- Attachments
- This the prot of the converter which i am telling above
- 20201203_194000.jpg (4.39 KiB) Viewed 395 times
- And this is the converter
- 20201203_194025.jpg (95.75 KiB) Viewed 395 times
- This is audio jack of my speaker
- 20201203_194250.jpg (68.3 KiB) Viewed 395 times
Re: I need some help with raspberry pi 3
Tell me if you dont understood the above message
I will explain in a better way
Last edited by Shashwat Gupta on Fri Dec 04, 2020 3:45 am, edited 1 time in total.
You should be able to find a cable that has female connectors on both ends
Then you just use it between the adapter and your speakers..
RPI3B+ - Raspberry Pi OS -general "playing" and/or RetroPi
RPI0W#1 - MotionEyeOS - yard surveillance
RPI0W#2 - Driveway gate monitor - coming soon
RPI0W#3 - ?????
RPI0W#3 - ?????
Ok
Will try
Will try
There is no female vga to female HDMI converter
There is only male HDMI to female vga
Please reply
Regards
Please reply
Regards
- RaTTuS
I'm not sure what your asking but things like
https://www.aliexpress.com/item/32851328158.html ?
https://www.aliexpress.com/item/4000056029541.html ?
may help ?
may help ?
Covfefe
Covfefe
sir i was telling that i have a vga monitor and on the raspberry pi 3 there"s a hdmi port only so i have to use a converter called hdmi to vga converter right??RaTTuS wrote: ↑Fri Dec 04, 2020 9:41 amI'm not sure what your asking but things like
may help ?
some body was telling that i should purchase the converter which is capable of converting vga to hdmi with a Audio port (hdmi to vga with audio converter) so that i dont have any problems .
but
the speAKERS i have is "attached" with a audio jack and it cannot be removed (from the speakers} and i have the only option to use speakers by connecting the audio jack {on the raspberry pi 3 audio port} and i have also dont have the option to connect a aux cable into my speakers
so my question was-
That can i directly connect the audio jack of my speakers into the port of the converter{image attached below} instead of using a aux cable??
please reply
regards
- Attachments
- IMG-20201204-WA0007.jpg (4.34 KiB) Viewed 225 times
- IMG-20201204-WA0006~2.jpg (79.34 KiB) Viewed 225 times
Shashwat Gupta wrote: ↑Fri Dec 04, 2020 10:29 amsir i was telling that i have a vga monitor and on the raspberry pi 3 there"s a hdmi port only so i have to use a converter called hdmi to vga converter right??RaTTuS wrote: ↑Fri Dec 04, 2020 9:41 amI'm not sure what your asking but things like
may help ?
but
so my question was-
please reply
regards
viewtopic.php?f=91&t=293157#p1772159
Please reply anyone
Sir you are sure ??fruitoftheloom wrote: ↑Fri Dec 04, 2020 10:37 amShashwat Gupta wrote: ↑Fri Dec 04, 2020 10:29 amsir i was telling that i have a vga monitor and on the raspberry pi 3 there"s a hdmi port only so i have to use a converter called hdmi to vga converter right??RaTTuS wrote: ↑Fri Dec 04, 2020 9:41 amI'm not sure what your asking but things like
may help ?
but
so my question was-
please reply
regards
