Hi all
So I have my Pi3 all setup with a desktop that I’ve been using, but I now want to use it with VNC on my iPad. I have it all set up with VNC but I have two questions
1) I want to run the Pi with no monitor, so switch it on and access it all from my iPad how can I do this (can I still connect a monitor later?)
2) I have VNC all set up and working fine except when I turn on the Rasperry Pi in the morning I have to type VNCserver in terminal each time so it will connect with my iPad. Any ideas of how to fix this as if I don’t use a monitor I won’t be able to gain access
I have VNC enabled in preferences.
Re: Headless remote use with VNC
no mention of:
1. what OS is installed on the RPi3B
2. what vnc server is installed on RPi3B
3. what vnc client is used on remote display....
....Request failed with status code 404...
Some people be like:
Hey LTolledo
1) Raspbian
2)Real VNC
3) VNC Viewer
1) Raspbian
2)Real VNC
3) VNC Viewer
I have:
RPi4B-4G, with
RPiOS32 full desktop, with
RealVNC server installed and enabled
VNCviewer is installed on my cheapo android phone
am able to view my RPi4B-4G on my android phone
and I dont need to enable VNC server every startup because its enabled by default
all of my Raspbian/RPiOS32 desktop setups have this by default...
RPi4B-4G, with
Is the desktop starting normally? If you boot then connect a screen is it up and running?
If not you could try forcing HDMI in config.txt
And specify a mode
https://www.raspberrypi.org/documentati ... t/video.md
hdmi_force_hotplug=1
If you run vncserver from command line it can create a virtual display for the desktop and share that. But then that isn't output to HDMI.
- Contact: Website
On RPi 4 by default if no HDMI is detected then no frame buffer is created so nothing that requires Desktop will run. eg VNC, audio apps, and I believe auto mounting.......
The usual fix is to enable force HDMI hotplug in config.txt or set a fixed resolution using sudo raspi-config (Choose anything other than default monitor)
Thanks PiGraham and Klricks
I have done the hdmi hotplug change in config.txt rebooted my pi and when I go into VNC viewer I just get
The port on which the computer is listening for a connection could not be contacted.
Not sure why
Not sure why
True.
But the OP is battling with an RPi3...
kaz69 wrote: Hi all
Is that only a Pi4 thing?
It's quick to try .
I took the OP to mean that with a monitor attached the desktop comes up and VNC works, but without the monitor at start-up VNC doesn't work without starting the server instance from command line and connecting a monitor later does not show the desktop. That sounds consistent with no frame buffer that klricks describes.
It's quick to try .
And if you plug your monitor in later, do you get the desktop now?
- Contact: Website
Yes it is a RPi4 thing and the symptoms are exactly as you wrote.PiGraham wrote: ↑Wed Nov 18, 2020 3:47 pmIs that only a Pi4 thing?
It's quick to try .
Other RPi versions don't have this issue as they revert to composite mode if HDMI is not connected at boot so a frame buffer is always created.
Due to clock timing issues, composite mode is disabled by default on RPi4. Don't know about the Pi400?
Sorry for the delay
I ran the sudo nano config.txt and sorted the hdmi side to things and looks to be working ok, as I started the pi up with the hdmi connected to the pi but not the TV. Then when I did connect the hdmi to the tv it came on all ok.
So now the issue is VNC not working unless I plug in the monitor go into terminal and type vncserver then I can get access from my iPad.
Not sure what’s happening as updated real VNC via terminal, enabled VNC via preferences and also in raspi-config
Morning all
So tested again this morning and hdmi part is all fine it’s just the VNC that’s the issue the only error messages that comes up is
But don’t think it means anything for the VNC issue
i dont know if its suggested already...but...
if you have a spare microSD card and a monitor:
1. flash it with the recently available RPiOS32 image
2. boot your RPi, update and upgrade
3. at the raspberry pi configuration change the password (and the hostname)
4. set VNC (and SSH) to enable
5. set your display resolution (just don't use default) like 1280 x 720, or 1360 x 768, or 1920 x 1080, etc (usually basing it on the monitor to be used on the VNC client)
optional: set your GPU memory from default to say 160MB
6. make sure the RPi is connected to your network (WiFi? wired LAN?)
7. reboot
8. examine if on the top right you see a VNC icon, if its there then the VNC server is enabled
9. determine your RPI's IP address...
10. power off and remove the monitor
11. power on the RPi.... wait at least until the rapid flashing subsides)
now go on to the other RPi (or iPad, or Android tablet/phone) and try to access via VNC your newly setup RPi...
7. reboot
So managed to get it all working.
LTolledo I looked at the top right for the VNC box and I signed back into my cloud account restarted and seems to be working fine, I had signed in originally but something happens where it logged me out.
Everyone thanks for the help all working nowp
