Joey R
I can't mount my HDD
Thu Nov 12, 2020 11:37 pm
I have a pi4 with a Mediasonic ProRaid 2 bay enclosure with 2 4tb WD NAS drives set to raid 1. I loaded Raspberry Pi OS Lite and installed Plex Media Server on it. I'm trying to mount the HHD but for some reason I can't get the FSTYPE or UUID or any other information on it other then the name being sda. Any and all help would be great
This is what I'm getting when I list all the disk partitions in CMD.
sudo lsblk -o UUID,NAME,FSTYPE,SIZE,MOUNTPOINT,LABEL,MODEL
UUID                                 NAME        FSTYPE  SIZE MOUNTPOINT LABEL  MODEL
                                     sda                 3.7T                   1
                                     mmcblk0            59.5G
4AD7-B4D5                            ├─mmcblk0p1 vfat    256M /boot      boot
2887d26c-6ae7-449d-9701-c5a4018755b0 └─mmcblk0p2 ext4   59.2G /          rootfs
HvdW
Re: I can't mount my HDD
Thu Nov 12, 2020 11:44 pm
You don't get something like this?
lsblk
NAME        MAJ:MIN RM  SIZE RO TYPE MOUNTPOINT
sda           8:0    0  1,8T  0 disk
└─sda1        8:1    0  1,8T  0 part /mnt/mydisk
sdb           8:16   0  3,7T  0 disk
├─sdb1        8:17   0  128M  0 part
└─sdb2        8:18   0  3,7T  0 part
mmcblk0     179:0    0  7,4G  0 disk
├─mmcblk0p1 179:1    0  256M  0 part /boot
└─mmcblk0p2 179:2    0  7,2G  0 part /
Who knows knows
Who doesn't doesn't
Joey R
Thu Nov 12, 2020 11:48 pm
This is what I get with lsblk
lsblk
sda           8:0    0  3.7T  0 disk
mmcblk0     179:0    0 59.5G  0 disk
└─mmcblk0p2 179:2    0 59.2G  0 part /
pidd
Fri Nov 13, 2020 12:54 am
How did you load RpiOS-lite and Plex Media Server onto it?
Joey R
Fri Nov 13, 2020 1:24 am
I loaded RpiOS-lite using Etcher and a 64gb micro sd card. I then installed plex using CMD.
pidd
Fri Nov 13, 2020 2:11 am
Ah, I thought you meant you had loaded them on the HDD.
From what you have shown so far, the HDD looks like it is partition-less? Perhaps you need to create a partition?
Joey R
Fri Nov 13, 2020 2:19 am
I already moved almost 1tb of media over. Is there a way to partition the drive and keep the full 3.7tb and not lose any of my data?
pidd
Fri Nov 13, 2020 2:31 am
We've had something similar before a few months ago on the forum, i can't remember the outcome.
I've no idea that is your problem, being a raid drive I've no idea what the normal partition tools make of it.
LTolledo
Re: I can't mount my RAID Drive
Fri Nov 13, 2020 10:40 am
the "RAID" showing up as sda only suggest there is no partition, and is not formatted...
how sure the OP has set the device as properly as RAID1 device?
how was the OP able to transfer files to the RAID1 device? what system was used?
can the OP show an image that there are files actually written on the RAID device?
have the OP tried setting up the device as a non-RAID unit and test if RPi can access that non-RAID device?
Some people be like:
Joey R
Fri Nov 13, 2020 2:03 pm
how sure the OP has set the device as properly as RAID1 device? It has presets on the back of the ensclosure and is set to RAID1. Also when plugged into my laptop, anything moved to one drive also gets sent to the other drive. This is how I know RAID1 is working.
how was the OP able to transfer files to the RAID1 device? what system was used? I plugged the enclosure to my laptop and I'm able to move files over to it.
can the OP show an image that there are files actually written on the RAID device? If you look at the image above it shows that 885gb of my media has been transferred over.
have the OP tried setting up the device as a non-RAID unit and test if RPi can access that non-RAID device? I have not
LTolledo
Fri Nov 13, 2020 8:42 pm
ok... thanks for answering the questions...
but before trying to do a non-RAID setting...
can you post the result of
lsusb
take note of the device ID
then look it up in
dmesg
and see why its not loading
(better post here that part of dmesg)
Joey R
Sun Nov 15, 2020 3:38 am
Here is what comes up with Isusb
pi@raspberrypi:~ $ lsusb
Bus 002 Device 002: ID 152d:0562 JMicron Technology Corp. / JMicron USA Technology Corp.
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Not sure what to search for in dmesg. A huge list comes up.
Joey R
Sun Nov 15, 2020 3:49 am
The only thing I see in dmesg that shows the HDD's is this.
 1.444635] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[    1.627616] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[    1.627667] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    1.627700] usb 1-1: Product: USB2.0 Hub
[    1.629867] hub 1-1:1.0: USB hub found
[    1.630143] hub 1-1:1.0: 4 ports detected
[    1.774987] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[    1.806325] usb 2-2: New USB device found, idVendor=152d, idProduct=0562, bcdDevice= 1.06
[    1.806369] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[    1.806401] usb 2-2: Product: JMS56x Series
[    1.806429] usb 2-2: Manufacturer: JMicron
[    1.806456] usb 2-2: SerialNumber: RANDOM__1B6A08401438
[    1.815890] systemd[1]: System time before build time, advancing clock.
[    1.836656] scsi host0: uas
[    1.838297] scsi 0:0:0:0: Direct-Access     H/W RAID 1                0106 PQ: 0 ANSI: 6
Hope this helps
Sun Nov 15, 2020 10:22 am
Do you get any other messages about uas (or UAS) in the dmesg output?
The JMicron adaptors seem to have a problem supporting that and need a "quirk" in /boot/cmdline.txt to make them use the more stable, but slower usb-storage driver instead.
Does your disk show up with the "blkid" or "fdisk -l" commands?
Unreadable squiggle
HawaiianPi
Sun Nov 15, 2020 11:05 am
Try adding the following to the beginning of the line in cmdline.txt with a single space after (before the rest of the line).
usb-storage.quirks=152d:0562:u
That should disable UAS for that device and use the USB mass storage driver.
Joey R
Mon Nov 16, 2020 12:37 am
The only other information on UAS i can find is
[    1.486644] usb 2-2: New USB device found, idVendor=152d, idProduct=0562, bcdDevice= 1.06
[    1.486685] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[    1.486717] usb 2-2: Product: JMS56x Series
[    1.486745] usb 2-2: Manufacturer: JMicron
[    1.486772] usb 2-2: SerialNumber: RANDOM__2D6BA993A16E
[    1.490953] usb 2-2: UAS is blacklisted for this device, using usb-storage instead
[    1.491101] usb 2-2: UAS is blacklisted for this device, using usb-storage instead
[    1.491139] usb-storage 2-2:1.0: USB Mass Storage device detected
[    1.491711] usb-storage 2-2:1.0: Quirks match for vid 152d pid 0562: 800000
[    1.491895] scsi host0: usb-storage 2-2:1.0
Joey R
Mon Nov 16, 2020 2:45 am
Not sure why but as soon I created a small partition(named dead space) it now shows up correctly and allows me the mount the NAS.
                                     sda                 3.7T                          1
                                     ├─sda1               16M
8A401E90401E82DD                     ├─sda2      ntfs    3.7T /mnt/NASberry NASberryPi
D0647E93647E7BD2                     └─sda3      ntfs     44M               dead space
