gworley
In DOS you can use the ESC to clear the command line.
Tue Oct 13, 2020 3:15 am
I cannot find this anywhere.
In DOS you can use the ESC key to clear the command line. It doesn't seem to work on the Raspberry Pi OS. Is there a single key stroke to do the same thing on the Raspberry Pi
Thank you,
George
kerry_s
Re: In DOS you can use the ESC to clear the command line.
Tue Oct 13, 2020 3:20 am
i think it's ctrl+l
i have an alias for clear so i'm more use to just typing clr.
trejan
Tue Oct 13, 2020 3:22 am
Ctrl+U will clear the line.
The escape key is already used by bash for various things so it isn't a good idea to rebind it. Run "bind -p" to see all the key bindings. \e is the escape key.
i think it's ctrl+l
That clears the screen.
klricks
Tue Oct 13, 2020 3:25 am
Not a single keystroke but does what you want. (LXterminal).
[Ctrl] /
also
[Ctrl] c
kerry_s
Tue Oct 13, 2020 3:34 am
:lol:
ctrl+a & ctrl+e are my most used. mv front & end
ctrl+w for deleting words, some times
most of the time i just can't remember & use the arrow, del or backspace. my minds not what it use to be. :lol:
NimbUx
Tue Oct 13, 2020 1:21 pm
[Ctrl+U] clears from the beginning of line to current cursor position : so
if cursor is already at end of line, [Ctrl+U] suffices. Else, or if you are unsure :
[End] followed by [Ctrl+U]
... will erase and make sure you a get a clear line at the terminal.
jahboater
Tue Oct 13, 2020 1:30 pm
This is all GNU readline stuff (the library used for reading text lines from the keyboard)
It is very powerful and can do vi or emac's style editing. There is a file ~/.inputrc (or /etc/inputrc) that can configure it.
see:
man readline
for all the details. Near the end of the man page is a full list of the emac's mode keybindings and the vi mode key bindings.
Pi4 8GB and Pi4 4GB running Raspberry Pi OS 64-bit
swampdog
Tue Oct 13, 2020 1:52 pm
"man readline" for everything. Note that you're in "emacs" mode by default.
Clear current line: CTRL-EU (ie: CTRL-E takes the cursor to eol and CTRL-U clears from eol to bol).
Clear screen: CTRL-L.
Cursor to bol: CTRL-A.
"CTRL-A #" is handy if you want to ignore the text. It moves cursor to bol then typing # is the same as a dos "rem" statement. You can just hit CR. Easier done than explained ;-)
