No matter what OS, no matter if it has a GUI, no matter if it uses systemd or sysvinit, are there any executable files that are going to exist in 100% of linux releases?
Weird question, I know. The reason why I ask is because I need a foolproof way of detecting whether what CPU architecture a given OS is meant for 32-bit, 64-bit, armhf, x86, you name it. And the detection must be done automatically and silently using a bash script.
(I thought the easiest way to detect it would be to find an executable file and detect what CPU architecture it's meant for)
Is there any executable file that is 100% going to be in /bin?
Want to run Minecraft Java on your RPi? Easiest way is with Pi-Apps - just click Install.
https://github.com/Botspot/pi-apps
Pi-Apps also includes Zoom, Visual Studio, Tor browser, Windows 10 theme, and 33 more.
Over 50,000 users!
Over 50,000 users!
Re: Is there any executable file that is 100% going to be in /bin?
Do you mean like "file /bin/sh" ?Botspot wrote: ↑Mon Oct 12, 2020 9:41 pmNo matter what OS, no matter if it has a GUI, no matter if it uses systemd or sysvinit, are there any executable files that are going to exist in 100% of linux releases?
I think /bin/sh will always be there even if its a link to /bin/dash
Pi4 8GB and Pi4 4GB running Raspberry Pi OS 64-bit
That could probably work.
But I'd have to find a way to follow the symlink or else when I try to detect the mimetype it will look like this:
$ file --mime-type -b /media/pi/pi-power-tools/bin/sh
inode/symlink
Over 50,000 users!
Over 50,000 users!
- DougieLawson
- Location: A small cave in deepest darkest Basingstoke, UK
- Contact: Website Twitter
You'll always have /sbin/init as that's the program that the kernel starts (unless you override it in /boot/cmdline.txt).
Another good answer. Too bad init can also be a symlink. Though again, I suppose the script could handle that and follow the symlink before getting the filetype.DougieLawson wrote: ↑Mon Oct 12, 2020 9:50 pmYou'll always have /sbin/init as that's the program that the kernel starts (unless you override it in /boot/cmdline.txt).
Over 50,000 users!
Over 50,000 users!
why not just do /bin/bash
i figure if it's a bash script & there's no bash your screwed anyways. i've never come across a linux without a bash shell or i don't remember.
- DougieLawson
If you're doing it in busybox then /bin/busybox must exist (unless you have some funky way of launching busybox).
POSIX mandates that /bin/sh must exist.
- DougieLawson
On RaspiOS that's a symlink to /bin/dash.
pi@ulysses:/bin $ ls -la sh
lrwxrwxrwx 1 root root 4 Jun 20 2019 sh -> dash
pi@ulysses:/bin $ readlink /bin/sh
dash
pi@ulysses:/bin $
Busybox based distributions don't have bash. Also if busybox is used as the init for a distribution then init is a script.
What are you trying to achieve by doing this anyway? The requirement it must work on everything is going to give you lots of weird edge cases to deal with like a multi arch install of Debian. Are you trying to write a system information script?
I agree there is going to be somewhere that doesn't put things in the same place or you have a 64 bit kernel and a 32 bit user land.
I was going to suggest parsing the uname output but then you might have trouble with that one too.
[root@amd-nixos:~]# ls -l /sbin
ls: cannot access '/sbin': No such file or directory
[root@amd-nixos:~]# ls -l /lib
ls: cannot access '/lib': No such file or directory
[root@amd-nixos:~]#
If you are going to use file to detect the mimetype, doesn't that imply that the file program is installed and working? If it is, then use file to check whether file itself is a 32-bit or 64-bit executable.Botspot wrote: ↑Mon Oct 12, 2020 9:47 pmThat could probably work.
But I'd have to find a way to follow the symlink or else when I try to detect the mimetype it will look like this:Code: Select all
$ file --mime-type -b /media/pi/pi-power-tools/bin/sh inode/symlink
$ file /usr/bin/file
/usr/bin/file: ELF 32-bit LSB executable, ARM, EABI5 version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux-armhf.so.3, for GNU/Linux 3.2.0, BuildID[sha1]=7df606942d83740a79979415e18b9960f0344ff2, stripped
I usually start with 'uname' and work from there but to answer your question, I guess we need to find a native executable using minimum tools..
The above ought to work for other unix as well, BSD's etc that don't have things like /proc/version and /etc/(os-release|redhat-release) and so forth. For instance, the above 'readlink' could be simplified via "-m" option but the BSD's don't have it.
#!/usr/bin/env sh
E="/bin/sh"
[ -f "$E" ] || exit 1
X=$(readlink "$E")
[ -z "$X" ] && X="$E"
X="$(which $X)"
$(which file) "$X" || exit 1
