Botspot
Is there any executable file that is 100% going to be in /bin?
Mon Oct 12, 2020 9:41 pm
No matter what OS, no matter if it has a GUI, no matter if it uses systemd or sysvinit, are there any executable files that are going to exist in 100% of linux releases?
Weird question, I know. The reason why I ask is because I need a foolproof way of detecting whether what CPU architecture a given OS is meant for 32-bit, 64-bit, armhf, x86, you name it. And the detection must be done automatically and silently using a bash script.
(I thought the easiest way to detect it would be to find an executable file and detect what CPU architecture it's meant for)
Want to run Minecraft Java on your RPi? Easiest way is with Pi-Apps - just click Install.
https://github.com/Botspot/pi-apps
Pi-Apps also includes Zoom, Visual Studio, Tor browser, Windows 10 theme, and 33 more.
Over 50,000 users!
jahboater
Re: Is there any executable file that is 100% going to be in /bin?
Mon Oct 12, 2020 9:43 pm
Do you mean like "file /bin/sh" ?
I think /bin/sh will always be there even if its a link to /bin/dash
Pi4 8GB and Pi4 4GB running Raspberry Pi OS 64-bit
Botspot
Mon Oct 12, 2020 9:47 pm
That could probably work.
But I'd have to find a way to follow the symlink or else when I try to detect the mimetype it will look like this:
$ file --mime-type -b /media/pi/pi-power-tools/bin/sh
inode/symlink
Over 50,000 users!
Mon Oct 12, 2020 9:50 pm
You'll always have /sbin/init as that's the program that the kernel starts (unless you override it in /boot/cmdline.txt).
Botspot
Mon Oct 12, 2020 9:53 pm
Another good answer. Too bad init can also be a symlink. Though again, I suppose the script could handle that and follow the symlink before getting the filetype.
Over 50,000 users!
kerry_s
Mon Oct 12, 2020 10:04 pm
why not just do /bin/bash
i figure if it's a bash script & there's no bash your screwed anyways. i've never come across a linux without a bash shell or i don't remember. :D
Mon Oct 12, 2020 10:25 pm
If you're doing it in busybox then /bin/busybox must exist (unless you have some funky way of launching busybox).
jahboater
Mon Oct 12, 2020 10:36 pm
POSIX mandates that /bin/sh must exist.
Mon Oct 12, 2020 10:44 pm
On RaspiOS that's a symlink to /bin/dash.
pi@ulysses:/bin $ ls -la sh
lrwxrwxrwx 1 root root 4 Jun 20  2019 sh -> dash
pi@ulysses:/bin $ readlink /bin/sh
dash
pi@ulysses:/bin $
DarkElvenAngel
Busybox based distributions don't have bash. Also if busybox is used as the init for a distribution then init is a script.
trejan
Mon Oct 12, 2020 11:30 pm
What are you trying to achieve by doing this anyway? The requirement it must work on everything is going to give you lots of weird edge cases to deal with like a multi arch install of Debian. Are you trying to write a system information script?
DarkElvenAngel
Mon Oct 12, 2020 11:40 pm
I agree there is going to be somewhere that doesn't put things in the same place or you have a 64 bit kernel and a 32 bit user land.
I was going to suggest parsing the uname output but then you might have trouble with that one too.
cleverca22
Tue Oct 13, 2020 3:42 am
[root@amd-nixos:~]# ls -l /sbin
ls: cannot access '/sbin': No such file or directory
[root@amd-nixos:~]# ls -l /lib
ls: cannot access '/lib': No such file or directory
[root@amd-nixos:~]#
not all distros conform to such rules!, parsing uname will likely be simpler, just "uname -m" i believe
ejolson
Tue Oct 13, 2020 3:51 am
inode/symlink
If you are going to use file to detect the mimetype, doesn't that imply that the file program is installed and working? If it is, then use file to check whether file itself is a 32-bit or 64-bit executable.
$ file /usr/bin/file
/usr/bin/file: ELF 32-bit LSB executable, ARM, EABI5 version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux-armhf.so.3, for GNU/Linux 3.2.0, BuildID[sha1]=7df606942d83740a79979415e18b9960f0344ff2, stripped
Of course that's in /usr/bin, so maybe not quite the answer you wanted.
swampdog
Tue Oct 13, 2020 1:28 pm
I usually start with 'uname' and work from there but to answer your question, I guess we need to find a native executable using minimum tools..
#!/usr/bin/env sh
E="/bin/sh"
[ -f "$E" ] || exit 1
X=$(readlink "$E")
[ -z "$X" ] && X="$E"
X="$(which $X)"
$(which file) "$X" || exit 1
The above ought to work for other unix as well, BSD's etc that don't have things like /proc/version and /etc/(os-release|redhat-release) and so forth. For instance, the above 'readlink' could be simplified via "-m" option but the BSD's don't have it.
