Botspot
How to download AND extract a .img.xz file?
Mon Oct 12, 2020 9:14 pm
Yes, I know how to click a download link. I also know how to extract the image once the download is completely finished.
I also know what command to run to simultaneously download and extract a .img.ZIP file. (That's how my img downloader is the fastest in the world) For future reference here it is:
wget -qO- https://downloads.raspberrypi.org/raspios_full_armhf_latest | busybox unzip - -p | dd bs=10M of=/location/for/extracted/image.img
But, I don't know how to do the same for a img.xz file. Does anyone out there know?
Want to run Minecraft Java on your RPi? Easiest way is with Pi-Apps - just click Install.
https://github.com/Botspot/pi-apps
Pi-Apps also includes Zoom, Visual Studio, Tor browser, Windows 10 theme, and 33 more.
Over 50,000 users!
Re: How to download AND extract a .img.xz file?
Mon Oct 12, 2020 9:20 pm
Install p7zip-full and it can unzip anything.
Botspot
Mon Oct 12, 2020 9:24 pm
I'd rather not require installing anything unless I really have to. (it's going into an application for Raspbian and I don't want unnecessary dependencies)
Maybe it's possible with tar?
Over 50,000 users!
Mon Oct 12, 2020 9:27 pm
It's either that or xz-utils. Pick your poison.
jahboater
Mon Oct 12, 2020 9:29 pm
You are using "busybox unzip - -p"
Perhaps it should be changed to "xz -d" or similar.
See "man xz" for details.
Pi4 8GB and Pi4 4GB running Raspberry Pi OS 64-bit
dustnbone
The normal command I use for .xz files is
tar -xJvf file.tar.xz
The J switch is the one that specifies the compression format (LZMA2) that .xz normally uses, as opposed to the z switch that specifies gzip compression.
Anyway that tar command (or something much like it, other options may apply to your use case) in place of your unzip command should do the job.
But as Dougie said xz support might require a package not included by default. Though it's common enough that it should be part of the OS image IMHO
Botspot
Mon Oct 12, 2020 9:33 pm
Hmm, tar doesn't seem to like the pipe.
pi@raspberrypi:~ $ wget -qO- https://archive.org/download/twister-osv-1-8-4.img/TwisterOSv1-8-4.img.xz | tar -xJvf | dd bs=10M of=/home/pi/twister.img
tar: option requires an argument -- 'f'
Try 'tar --help' or 'tar --usage' for more information.
0+0 records in
0+0 records out
0 bytes copied, 0.00760547 s, 0.0 kB/s
pi@raspberrypi:~ $ wget -qO- https://archive.org/download/twister-osv-1-8-4.img/TwisterOSv1-8-4.img.xz | tar -xJvf - | dd bs=10M of=/home/pi/twister.img
tar: This does not look like a tar archive
tar: Skipping to next header
tar: Exiting with failure status due to previous errors
0+0 records in
0+0 records out
0 bytes copied, 0.699537 s, 0.0 kB/s
Over 50,000 users!
Botspot
Mon Oct 12, 2020 9:35 pm
I'm familiar with xz so you think I would have tried that in a pipe! (Spent the past several days trying tar commands, all to no success)
This appears to be working:
wget -qO- https://archive.org/download/twister-osv-1-8-4.img/TwisterOSv1-8-4.img.xz | xz -d - | dd bs=10M of=/home/pi/twister.img
Over 50,000 users!
jahboater
Mon Oct 12, 2020 9:40 pm
I'm glad "xz -d" works!
Just for my interest, why are you using "bs=10M" for the dd command?
The cp command (which is very fast in my tests) uses just 128KB block size (see strace cp ....)
Botspot
Mon Oct 12, 2020 9:45 pm
In my tests, I found it gives a bit of a buffer. It usually cut down on download time by around 3 seconds. (and when you want to have the world's fastest img downloader, every second counts.)
Additionally, in my script I go a couple steps further by loading the first 100MB of the img into cache first, and also it uses the buffer package to overcome I/O bottlenecks for maximum efficiency.
Over 50,000 users!
jahboater
Mon Oct 12, 2020 10:01 pm
Cool! Sounds like you have thought about it!!!
The copy does read/write in a loop. Since we have two different devices on two different buses, Linux will do them in parallel automatically (asynchronous prefetch). Reading and writing will happen at the same time, overlapped - which gives the biggest speed in a copy. But of course writing cannot start until the first read completes and if that read is huge, time is wasted. I have seen people set the block size to the size of the file - meaning that the copy time is simply doubled!!! Aaaah!
So I don't use any special software, just let the kernel do it all for me!
Botspot
Mon Oct 12, 2020 10:08 pm
Thank you.
Believe it or not, with enough optimization, it can be faster to download an img, extract it, and flash it to a SD card, than to flash a local, pre-extracted .img to a SD Card.
Over 50,000 users!
jahboater
Mon Oct 12, 2020 10:31 pm
Yes I'm sure it can.
Its incredibly complicated given: different read/download speeds, decompression speeds, indeterminate overlap between reads and writes, disk write speeds, variable asynchronous disk block prefetch ranges, "sync" time, verification time, etc etc
Given all the above variables, any simple benchmark results will be meaningless ...
For example, I usually download the image to a memory disk, then uncompress it and copy it to the raw device.
So, given that the disk read times are near zero for this case only, whats the best read/write block size to give dd for the optimal overlap between reads and writes?
I gave up trying to calculate everything and produce an optimal C program!
Now I just use "cp" - its simple to use and fast enough in practice (slightly faster than dd bs=1m)
cleverca22
Tue Oct 13, 2020 4:12 am
what if you dont even use dd, just `wget ... | xz -d > foo.img` ?
Botspot
Tue Oct 13, 2020 12:45 pm
I'm pretty sure that a simple '>' would do it one bit at a time. Even if it didn't, without a buffer the whole pipe is sensitive to slowdowns.
For example, when flashing directly from the internet, I found that some USB devices occasionally did a flush or something, and that causes a periodic slowdown. With two consecutive buffers, the pipe could keep downloading and extracting for a while in the background.
But without a buffer, the whole pipe would immediately slow down at once, and would rarely ever reach full speed again.
Over 50,000 users!
jahboater
Tue Oct 13, 2020 1:02 pm
Its writes with a block size of 8KB (probably BUFSIZ). But likely the speed is limited by the decompress time, as the writes will go straight into memory (the disk cache). Sync must be used afterwards.
You can see the I/O reads and writes for any command with strace, for example:
strace xz -d Python-3.9.0.tar.xz - >tmp
But you cant see whats going on behind the scenes in the kernel.
Note that cp optimizes prefetch (with POSIX_FADV_SEQUENTIAL ) but dd does not.
Prefetch is key to getting fast overall copy times because it allows the writes to proceed at the same time as the reads, hopefully nearly halving the total time.
That's one reason why commands like cp use a smallish block size (128 KB) because writing cannot commence until the first block read has completed. Giving a huge block size to dd removes much, or all, of the overlap between the reads and the writes!
