phil_mw60
Resolution Woes
Mon Jan 07, 2013 9:06 pm
I have my RPi connected to a fairly small 32" TV via the HDMI output and by default it is using 640 x 480 resolution, which is of course very small and means I have to scroll around the screen a lot.
I've tested modifying some of the settings in /boot/config.txt e.g uncommenting hdmi_safe=1 and when I do this I get a very high resolution which is at the opposite end of the scale! Ie I can hardly read the text it appears so small.
Does anyone know how I can set a mid-size resolution maybe 800 x 600? When I run the following command:
# /opt/vc/bin/tvservice –m CEA
I get a message saying the only available resolution is 640 x 480!
Thanks for any help.
Phil
phil_mw60
Re: Resolution Woes
Mon Jan 07, 2013 9:09 pm
Edit:
I meant 24" TV not 32"!
Edit 2:
I've modified the
#framebuffer_width and #framebuffer_height parameters to 800 x 600 and this seems to have given me a better resolution.
Mobius
Re: Resolution Woes
Tue Jan 08, 2013 1:10 am
phil_mw60 wrote:Edit:
Edit 2:
I've modified the
hdmi_safe=1 is supposed to force hotplug and set a resolution of 640x480. Instead, I use the force hotpug line (because I have an HDMI to VGA adapter) and use the framebuffer lines to set my desired resolution. The hdmi_mode and hdmi_group are supposed to allow setting for fixed resolutions but I couldn't get them to work at the resolution I needed.
phil_mw60
Re: Resolution Woes
Tue Jan 08, 2013 11:14 am
Thanks mobius, I've also used the framebuffer lines to set my required resolution.
Now I just need to play around with the overscan settings as there is an area of black space around my Pi display which could be used!
Thanks.
Phil
