First timer here, please bare with me (Windows guy). I recently set a 3A+ and want to connect via ethernet USB adapter. I know the adapter works based on another devices.
I currently have it on a HUB, but once working (I've tested without with no success) it will be removed.
Here is the output of a few commands to help troubleshoot please.
pi@PiHole:~ $ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.4.51-v7+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1333 SMP Mon Aug 10 16:45:19 BST 2020
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model A Plus Rev 1.0
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Reserved memory: created CMA memory pool at 0x17c00000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] On node 0 totalpages: 114688
[ 0.000000] Normal zone: 1008 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 114688 pages, LIFO batch:31
[ 0.000000] percpu: Embedded 20 pages/cpu s49856 r8192 d23872 u81920
[ 0.000000] pcpu-alloc: s49856 r8192 d23872 u81920 alloc=20*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 113680
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=1680 bcm2708_fb.fbheight=1050 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 console=ttyS0,115200 console=tty1 root=PARTUUID=0e30f08c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 374400K/458752K available (8192K kernel code, 689K rwdata, 2552K rodata, 1024K init, 825K bss, 18816K reserved, 65536K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 28275 entries in 56 pages
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] random: get_random_bytes called from start_kernel+0x328/0x500 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000019] Switching to timer-based delay loop, resolution 52ns
[ 0.000285] Console: colour dummy device 80x30
[ 0.000313] printk: console [tty1] enabled
[ 0.000364] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000384] pid_max: default: 32768 minimum: 301
[ 0.000760] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.000778] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.002133] Disabling memory control group subsystem
[ 0.002232] CPU: Testing write buffer coherency: ok
[ 0.002794] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.003728] Setting up static identity map for 0x100000 - 0x10003c
[ 0.003922] rcu: Hierarchical SRCU implementation.
[ 0.004600] smp: Bringing up secondary CPUs ...
[ 0.005712] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.006986] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.008131] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.008283] smp: Brought up 1 node, 4 CPUs
[ 0.008299] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.008309] CPU: All CPU(s) started in HYP mode.
[ 0.008317] CPU: Virtualization extensions available.
[ 0.009201] devtmpfs: initialized
[ 0.025924] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.026191] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.026218] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.029290] pinctrl core: initialized pinctrl subsystem
[ 0.030536] NET: Registered protocol family 16
[ 0.034870] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.041287] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.041299] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.041534] Serial: AMBA PL011 UART driver
[ 0.043511] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.060098] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-08-19 17:40, variant start
[ 0.070117] raspberrypi-firmware soc:firmware: Firmware hash is e90cba19a98a0d1f2ef086b9cafcbca00778f094
[ 0.121829] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.124016] SCSI subsystem initialized
[ 0.124271] usbcore: registered new interface driver usbfs
[ 0.124333] usbcore: registered new interface driver hub
[ 0.124457] usbcore: registered new device driver usb
[ 0.126539] clocksource: Switched to clocksource arch_sys_counter
[ 1.287287] VFS: Disk quotas dquot_6.6.0
[ 1.287402] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.287599] FS-Cache: Loaded
[ 1.287864] CacheFiles: Loaded
[ 1.298959] thermal_sys: Registered thermal governor 'step_wise'
[ 1.299359] NET: Registered protocol family 2
[ 1.300407] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 1.300452] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 1.300520] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 1.300620] TCP: Hash tables configured (established 4096 bind 4096)
[ 1.300754] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 1.300790] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 1.301065] NET: Registered protocol family 1
[ 1.301770] RPC: Registered named UNIX socket transport module.
[ 1.301780] RPC: Registered udp transport module.
[ 1.301790] RPC: Registered tcp transport module.
[ 1.301799] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.303634] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 1.306987] Initialise system trusted keyrings
[ 1.307243] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 1.319029] FS-Cache: Netfs 'nfs' registered for caching
[ 1.319837] NFS: Registering the id_resolver key type
[ 1.319889] Key type id_resolver registered
[ 1.319899] Key type id_legacy registered
[ 1.319919] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.321236] Key type asymmetric registered
[ 1.321248] Asymmetric key parser 'x509' registered
[ 1.321299] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 1.321311] io scheduler mq-deadline registered
[ 1.321322] io scheduler kyber registered
[ 1.324755] bcm2708_fb soc:fb: FB found 1 display(s)
[ 1.359842] Console: switching to colour frame buffer device 210x65
[ 1.389433] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1680x1050
[ 1.394682] bcm2835-rng 3f104000.rng: hwrng registered
[ 1.395160] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 1.395897] vc-sm: Videocore shared memory driver
[ 1.396355] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 1.409476] brd: module loaded
[ 1.422404] loop: module loaded
[ 1.423832] Loading iSCSI transport class v2.0-870.
[ 1.424727] libphy: Fixed MDIO Bus: probed
[ 1.424845] usbcore: registered new interface driver lan78xx
[ 1.424908] usbcore: registered new interface driver smsc95xx
[ 1.424935] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 2.153225] Core Release: 2.80a
[ 2.153240] Setting default values for core params
[ 2.153276] Finished setting default values for core params
[ 2.353669] Using Buffer DMA mode
[ 2.353680] Periodic Transfer Interrupt Enhancement - disabled
[ 2.353689] Multiprocessor Interrupt Enhancement - disabled
[ 2.353702] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.353728] Dedicated Tx FIFOs mode
[ 2.354299] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = 97d14000 dma = 0xd7d14000 len=9024
[ 2.354329] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 2.354341] dwc_otg: Microframe scheduler enabled
[ 2.354407] WARN::hcd_init_fiq:457: FIQ on core 1
[ 2.354417] WARN::hcd_init_fiq:458: FIQ ASM at 806d89f4 length 36
[ 2.354428] WARN::hcd_init_fiq:497: MPHI regs_base at 9c810000
[ 2.354450] dwc_otg 3f980000.usb: DWC OTG Controller
[ 2.354490] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 2.354537] dwc_otg 3f980000.usb: irq 56, io mem 0x00000000
[ 2.354590] Init: Port Power? op_state=1
[ 2.354600] Init: Power Port (0)
[ 2.354969] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ 2.354986] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.355000] usb usb1: Product: DWC OTG Controller
[ 2.355014] usb usb1: Manufacturer: Linux 5.4.51-v7+ dwc_otg_hcd
[ 2.355027] usb usb1: SerialNumber: 3f980000.usb
[ 2.355723] hub 1-0:1.0: USB hub found
[ 2.355787] hub 1-0:1.0: 1 port detected
[ 2.356636] dwc_otg: FIQ enabled
[ 2.356646] dwc_otg: NAK holdoff enabled
[ 2.356656] dwc_otg: FIQ split-transaction FSM enabled
[ 2.356672] Module dwc_common_port init
[ 2.357032] usbcore: registered new interface driver usb-storage
[ 2.357240] mousedev: PS/2 mouse device common for all mice
[ 2.358596] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 2.360056] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 600000 KHz
[ 2.362833] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 700000 KHz
[ 2.363440] sdhci: Secure Digital Host Controller Interface driver
[ 2.363448] sdhci: Copyright(c) Pierre Ossman
[ 2.363949] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
[ 2.364494] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ 2.364678] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.366388] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.366767] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.366922] usbcore: registered new interface driver usbhid
[ 2.366930] usbhid: USB HID core driver
[ 2.367822] vchiq: vchiq_init_state: slot_zero = (ptrval)
[ 2.369523] [vc_sm_connected_init]: start
[ 2.379066] [vc_sm_connected_init]: end - returning 0
[ 2.380817] Initializing XFRM netlink socket
[ 2.380854] NET: Registered protocol family 17
[ 2.380987] Key type dns_resolver registered
[ 2.381686] Registering SWP/SWPB emulation handler
[ 2.381989] registered taskstats version 1
[ 2.382008] Loading compiled-in X.509 certificates
[ 2.382501] Key type ._fscrypt registered
[ 2.382511] Key type .fscrypt registered
[ 2.392066] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 2.392153] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 81, base_baud = 0) is a PL011 rev2
[ 2.393935] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 2.395270] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 2.395283] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[ 2.420195] sdhost: log_buf @ (ptrval) (d7d13000)
[ 2.456223] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.458000] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.459624] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.462540] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.471307] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 2.473549] of_cfs_init
[ 2.473679] of_cfs_init: OK
[ 2.494735] Waiting for root device PARTUUID=0e30f08c-02...
[ 2.531738] random: fast init done
[ 2.533515] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.536811] mmc0: new high speed SDHC card at address 1234
[ 2.537776] mmcblk0: mmc0:1234 SA16G 14.5 GiB
[ 2.540183] mmcblk0: p1 p2
[ 2.553699] mmc1: new high speed SDIO card at address 0001
[ 2.561123] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.561222] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.562078] devtmpfs: mounted
[ 2.566707] Indeed it is in host mode hprt0 = 00021501
[ 2.628767] Freeing unused kernel memory: 1024K
[ 2.656927] Run /sbin/init as init process
[ 2.776603] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.777089] Indeed it is in host mode hprt0 = 00001101
[ 3.019381] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.54
[ 3.019399] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.019411] usb 1-1: Product: USB2.1 Hub
[ 3.019424] usb 1-1: Manufacturer: GenesysLogic
[ 3.020260] hub 1-1:1.0: USB hub found
[ 3.020569] hub 1-1:1.0: 4 ports detected
[ 3.279464] systemd[1]: System time before build time, advancing clock.
[ 3.356589] usb 1-1.2: new low-speed USB device number 3 using dwc_otg
[ 3.427375] NET: Registered protocol family 10
[ 3.428617] Segment Routing with IPv6
[ 3.476133] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 3.477143] systemd[1]: Detected architecture arm.
[ 3.513437] usb 1-1.2: New USB device found, idVendor=0e8f, idProduct=2517, bcdDevice= 1.00
[ 3.513509] usb 1-1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.528581] input: HID 0e8f:2517 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:0E8F:2517.0001/input/input0
[ 3.529558] systemd[1]: Set hostname to <PiHole>.
[ 3.597599] hid-generic 0003:0E8F:2517.0001: input,hidraw0: USB HID v1.10 Keyboard [HID 0e8f:2517] on usb-3f980000.usb-1.2/input0
[ 3.614219] input: HID 0e8f:2517 Consumer Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:0E8F:2517.0002/input/input1
[ 3.676958] input: HID 0e8f:2517 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:0E8F:2517.0002/input/input2
[ 3.677190] input: HID 0e8f:2517 Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:0E8F:2517.0002/input/input3
[ 3.677634] hid-generic 0003:0E8F:2517.0002: input,hidraw1: USB HID v1.10 Mouse [HID 0e8f:2517] on usb-3f980000.usb-1.2/input1
[ 4.361436] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.374564] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.375217] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 4.403016] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[ 4.403207] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.404086] systemd[1]: Listening on Journal Socket.
[ 4.404739] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 4.412986] systemd[1]: Listening on Syslog Socket.
[ 4.420071] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 4.420324] systemd[1]: Reached target Swap.
[ 4.520866] i2c /dev entries driver
[ 5.113094] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 5.210959] systemd-journald[113]: Received request to flush runtime journal from PID 1
[ 5.773740] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.775956] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 5.775978] [vc_sm_connected_init]: start
[ 5.781600] [vc_sm_connected_init]: installed successfully
[ 5.787675] mc: Linux media interface: v0.10
[ 5.852063] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.858755] videodev: Linux video capture interface: v2.00
[ 5.876310] bcm2835_audio bcm2835_audio: card created with 4 channels
[ 5.882436] bcm2835_audio bcm2835_audio: card created with 4 channels
[ 5.893207] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.894665] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.895418] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.904127] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.914580] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.925132] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 5.925822] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 5.926311] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 5.927380] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 5.927411] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 5.927430] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 5.927446] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 5.927464] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 5.927645] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 5.935873] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.955596] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 5.955652] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 5.961250] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 5.961311] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 5.970534] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 5.970589] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 6.284528] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 6.454006] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 6.534680] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 6.548790] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 6.549443] usbcore: registered new interface driver brcmfmac
[ 6.629237] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,3-model-b-plus.txt failed with error -2
[ 6.845685] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 6.900237] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 23 2020 02:19:54 version 7.45.206 (r725000 CY) FWID 01-88ee44ea
[ 8.504442] random: crng init done
[ 8.504461] random: 7 urandom warning(s) missed due to ratelimiting
[ 8.667340] uart-pl011 3f201000.serial: no DMA platform data
[ 9.016767] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 15.611051] Bluetooth: Core ver 2.22
[ 15.611115] NET: Registered protocol family 31
[ 15.611120] Bluetooth: HCI device and connection manager initialized
[ 15.611136] Bluetooth: HCI socket layer initialized
[ 15.611146] Bluetooth: L2CAP socket layer initialized
[ 15.611160] Bluetooth: SCO socket layer initialized
[ 15.627377] Bluetooth: HCI UART driver ver 2.3
[ 15.627389] Bluetooth: HCI UART protocol H4 registered
[ 15.627431] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 15.627571] Bluetooth: HCI UART protocol Broadcom registered
[ 16.008194] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 16.008204] Bluetooth: BNEP filters: protocol multicast
[ 16.008222] Bluetooth: BNEP socket layer initialized
[ 16.075577] Bluetooth: RFCOMM TTY layer initialized
[ 16.075612] Bluetooth: RFCOMM socket layer initialized
[ 16.075630] Bluetooth: RFCOMM ver 1.11
[ 21.621795] fuse: init (API version 7.31)
Couldn't open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bDeviceProtocol 1 Single TT
bMaxPacketSize0 64
idVendor 0x1d6b Linux Foundation
idProduct 0x0002 2.0 root hub
bcdDevice 5.04
iManufacturer 3
iProduct 2
iSerial 1
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9 Hub
bInterfaceSubClass 0
bInterfaceProtocol 0 Full speed (or root) hub
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 12
auto eth0
auto eth1
iface eth1 inet static
address 192.168.x.x
netmask 255.255.x.x
gateway 192.168.x.x
auto lo
iface lo inet lopback
interface eth1
static ip_adress=192.168.x.x/xx
static routers=192.168.x.x
inform 192.168.x.x
static domain_name_servers=8.8.8.8
