Connecting Servo Motor and LEDs to Raspberry Pi
Posted: Sat Oct 03, 2020 3:08 am
Hi guys, I am connecting a Servo MG995 and 1W White LED to my Raspberry Pi with an external Switching Power Supply Unit 5V/5A.
Also having a MOSFET as a switch controlled by the GPIO.
I want to have the LED and Servo working at the same time but its not working well I think is because insufficient voltage or current?
When both are working at the same time, the LED lights up brightly but the Servo couldn't work, looks like its struggling for power.
But when i remove the LED, the servo works well.
The operating voltage for servo is 4.8V - 7.2V.
I measured the current passing through the LED is about 0.35A and servo 0.2A~
I am not sure about electronics stuffs, I mean should I purchase a 12V power supply? But will that overkill the 1W LED and servo motor?
The switching power supply unit i can only have 5V/12V/24V though...but I can purchase higher Ampere supply like 5V - 10A/20A
Also I would like to add another servo, any advice on what kind of power supply values I should get?
