how to add to PATH
Posted: Wed Sep 30, 2020 4:46 pm
by Rcayot
I recently tried to add a board to my Arduino IDE, it apparently needed an NRFutil program which I installed, and got the following message:
"The script adafruit-nrfutil is installed in '/home/pi/.local/bin' which is not on PATH."
Also when I tried to install the board, the Arduino IDE gave the following message:
nrfutil not available on this operating system.
So, the board installation page has this advice:
"Add pip3 installation dir to your PATH if it is not added already. Make sure adafruit-nrfutil can be executed in terminal by running"
anyway, how do I add this to PATH?
Roger
Re: how to add to PATH
Posted: Wed Sep 30, 2020 4:50 pm
by jahboater
Rcayot wrote: ↑Wed Sep 30, 2020 4:46 pm
If you want it first on the search path:
or last on the search path:
Posted: Wed Sep 30, 2020 5:23 pm
by Rcayot
Thanks, that partially worked!
When I run from terminal
:pi@raspberrypi:~ $ adafruit-nrfutil version
adafruit-nrfutil version 0.5.3.post12
pi@raspberrypi:~ $
nrfutil file is found, but when I try to install the board on the Arduino IDE, I get the following message:
"Tool nrfprog is not available for your operating system"
Still stuck, will go back to Adafruit customer support... but anything anyone here can help with would be great!
Roger
Posted: Wed Sep 30, 2020 5:30 pm
by dbrion06
Posted: Wed Sep 30, 2020 5:31 pm
by GlowInTheDark
Note that there are at least 3 different questions being asked here:
1) How do I add something (temporarily) to my $PATH variable in the shell?
2) How do I do the above in a way that is permanent (i.e., will persist across different invocations of the shell and/or reboots) ?
3) What is wrong with my Arduino IDE installation? Why doesn't it "just work" like it should?
#1 has been answered above.
I suspect #3 is the one the OP is actually interested in.
Posted: Wed Sep 30, 2020 5:46 pm
by Rcayot
well yes, #1 has been answered.
I suspect that I need to have #2 answered. Then I can see if that will help with #3 as the guide on Adafruit for the board says that testing the path by running a simple 'version' argument will result in an an error free version, and it does, but still does not get me past the board install.
Thanks,
Roger
Posted: Wed Sep 30, 2020 6:11 pm
by jahboater
Rcayot wrote: ↑Wed Sep 30, 2020 5:46 pm
That's easy.
There is a file in your home directory called ".bashrc"
You may edit it with "nano ~/.bashrc" and add the PATH= stuff there.
It will then always be available.
Posted: Wed Sep 30, 2020 6:57 pm
by GlowInTheDark
Actually, it is better to set PATH in .profile than .bashrc (or other places).
By the way, I often see references to .local/bin or maybe .config/bin or whatever. Where do these comes from? I always just use ~/bin (which is what the code in the .profile supports).
Posted: Wed Sep 30, 2020 8:06 pm
by jahboater
GlowInTheDark wrote: ↑Wed Sep 30, 2020 6:57 pm
See .profile as you suggested above ...
# set PATH so it includes user's private bin if it exists
if [ -d "$HOME/bin" ] ; then
PATH="$HOME/bin:$PATH"
fi
if [ -d "$HOME/.local/bin" ] ; then
PATH="$HOME/.local/bin:$PATH"
fi
