Blast
best power supply for model b raspberry pi
Sat Jan 05, 2013 10:03 pm
hello, I've got everything to run my raspberry pi except a power supply
what is the best power supply for the model b version that won't flake out on me, i'm going to have a keyboard & mouse connected to the raspberry pi so i need enough power to keep everything powered without losing stability
i'm quite confused with what is the recommended power supply because i've read that everybody uses something different
would appreciate the help
mahjongg
Re: best power supply for model b raspberry pi
Sat Jan 05, 2013 10:20 pm
Especially If you are in the US, I would recommend getting the one from adafruit.
https://www.adafruit.com/products/501/
Blast
Sat Jan 12, 2013 12:51 am
i'm in canada
what cables does it come with?
efflandt
Sat Jan 12, 2013 1:10 am
It does not come with any cable. It has a regular USB port, so if you do not have a USB to microUSB cable from a phone, you will need one.
I don't know if you have Rayovac in stores north of the border (I think they are in Wisconsin), but I got an Adafruit 501 through element14/newark and have also been using a Rayovac USB Wall Charger on another that seems to work as well. http://www.rayovac.com/Products/Recharg ... arger.aspx
jwhitehorn
Sat Jan 12, 2013 3:18 am
Not having a micro USB cable, I just went with the 1A power adapter from Newark:
http://www.newark.com/mcm/mws5-0501000u ... dp/27W9241
It's a single unit with the cable and adapter as one piece. So far it's been working out great, and at that price I couldn't argue.
Blast
Sat Jan 12, 2013 6:56 am
would this be good enough to keep everything powered nicely???
http://canada.newark.com/mcm/mws5-05010 ... dp/27W9241
++bahjatk++
Sat Jan 12, 2013 11:12 am
Blast wrote:would this be good enough to keep everything powered nicely???
If it is 5v, then yes it will.
You basically need any power adapter with a micro usb end, and requiring it to be 5v, and 750mA or more (1A is 1000mA, so it is suitable)
jwhitehorn
Sat Jan 12, 2013 10:30 pm
Look one post above you :lol:
Yes, that power supply is working very nicely for me.
