I've reinstalled mysql so i can give logs
pi@lech ~ $ sudo service mysql status
[info] /usr/bin/mysqladmin Ver 8.42 Distrib 5.5.28, for debian-linux-gnu on armv7l
Copyright (c) 2000, 2012, Oracle and/or its affiliates. All rights reserved.
Oracle is a registered trademark of Oracle Corporation and/or its
affiliates. Other names may be trademarks of their respective
owners.
Server version 5.5.28-1
Protocol version 10
Connection Localhost via UNIX socket
UNIX socket /var/run/mysqld/mysqld.sock
Uptime: 1 hour 47 min 54 sec
Threads: 1 Questions: 402 Slow queries: 0 Opens: 44 Flush tables: 1 Open tables: 37 Queries per second avg: 0.062.
owners.
Protocol version 10
Uptime: 1 hour 48 min 55 sec
Threads: 9 Questions: 524 Slow queries: 0 Opens: 44 Flush tables: 1 Open tables: 37 Queries per second avg: 0.080.
It died 1-2minutes later.
I had heavy lag on console - couldn''t type. server seemed to use a lot of CPU
here are logs from /var/log/daemon.log
Jan 7 08:36:16 lech mysqld_safe: Starting mysqld daemon with databases from /var/lib/mysql
Jan 7 08:36:16 lech mysqld: 130107 8:36:16 [Note] Plugin 'FEDERATED' is disabled.
Jan 7 08:36:16 lech mysqld: 130107 8:36:16 InnoDB: The InnoDB memory heap is disabled
Jan 7 08:36:16 lech mysqld: 130107 8:36:16 InnoDB: Mutexes and rw_locks use GCC atomic builtins
Jan 7 08:36:16 lech mysqld: 130107 8:36:16 InnoDB: Compressed tables use zlib 1.2.7
Jan 7 08:36:16 lech mysqld: 130107 8:36:16 InnoDB: Using Linux native AIO
Jan 7 08:36:16 lech mysqld: 130107 8:36:16 InnoDB: Initializing buffer pool, size = 128.0M
Jan 7 08:36:16 lech mysqld: 130107 8:36:16 InnoDB: Completed initialization of buffer pool
Jan 7 08:36:16 lech mysqld: 130107 8:36:16 InnoDB: highest supported file format is Barracuda.
Jan 7 08:36:16 lech mysqld: InnoDB: The log sequence number in ibdata files does not match
Jan 7 08:36:16 lech mysqld: InnoDB: the log sequence number in the ib_logfiles!
Jan 7 08:36:16 lech mysqld: 130107 8:36:16 InnoDB: Database was not shut down normally!
Jan 7 08:36:16 lech mysqld: InnoDB: Starting crash recovery.
Jan 7 08:36:16 lech mysqld: InnoDB: Reading tablespace information from the .ibd files...
Jan 7 08:36:16 lech mysqld: InnoDB: Restoring possible half-written data pages from the doublewrite
Jan 7 08:36:16 lech mysqld: InnoDB: buffer...
Jan 7 08:36:17 lech mysqld: 130107 8:36:17 InnoDB: Waiting for the background threads to start
Jan 7 08:36:18 lech mysqld: 130107 8:36:18 InnoDB: 1.1.8 started; log sequence number 5774308
Jan 7 08:36:19 lech mysqld: 130107 8:36:19 [Note] Server hostname (bind-address): '127.0.0.1'; port: 3306
Jan 7 08:36:19 lech mysqld: 130107 8:36:19 [Note] - '127.0.0.1' resolves to '127.0.0.1';
Jan 7 08:36:19 lech mysqld: 130107 8:36:19 [Note] Server socket created on IP: '127.0.0.1'.
Jan 7 08:36:19 lech mysqld: 130107 8:36:19 [Note] Event Scheduler: Loaded 0 events
Jan 7 08:36:19 lech mysqld: 130107 8:36:19 [Note] /usr/sbin/mysqld: ready for connections.
Jan 7 08:36:19 lech mysqld: Version: '5.5.28-1' socket: '/var/run/mysqld/mysqld.sock' port: 3306 (Debian)
Jan 7 10:28:44 lech mysqld_safe: Number of processes running now: 0
Jan 7 10:28:59 lech mysqld_safe: mysqld restarted
Jan 7 10:36:02 lech mysqld: 130107 10:36:02 [Note] Plugin 'FEDERATED' is disabled.
Jan 7 10:36:02 lech mysqld: 130107 10:36:02 InnoDB: The InnoDB memory heap is disabled
Jan 7 10:36:02 lech mysqld: 130107 10:36:02 InnoDB: Mutexes and rw_locks use GCC atomic builtins
Jan 7 10:36:02 lech mysqld: 130107 10:36:02 InnoDB: Compressed tables use zlib 1.2.7
Jan 7 10:36:02 lech mysqld: 130107 10:36:02 InnoDB: Using Linux native AIO
Jan 7 10:36:02 lech mysqld: 130107 10:36:02 InnoDB: Initializing buffer pool, size = 128.0M
Jan 7 10:36:02 lech mysqld: InnoDB: mmap(135987200 bytes) failed; errno 12
Jan 7 10:36:02 lech mysqld: 130107 10:36:02 InnoDB: Completed initialization of buffer pool
Jan 7 10:36:02 lech mysqld: 130107 10:36:02 InnoDB: Fatal error: cannot allocate memory for the buffer pool
Jan 7 10:36:02 lech mysqld: 130107 10:36:02 [ERROR] Plugin 'InnoDB' init function returned error.
Jan 7 10:36:02 lech mysqld: 130107 10:36:02 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
Jan 7 10:36:02 lech mysqld: 130107 10:36:02 [ERROR] Unknown/unsupported storage engine: InnoDB
Jan 7 10:36:02 lech mysqld: 130107 10:36:02 [ERROR] Aborting
Jan 7 10:36:02 lech mysqld: 130107 10:36:02 [Note] /usr/sbin/mysqld: Shutdown complete
Jan 7 10:36:02 lech mysqld_safe: mysqld from pid file /var/run/mysqld/mysqld.pid ended
and here /var/log/syslog
Jan 7 08:39:01 lech /USR/SBIN/CRON[23763]: (root) CMD ( [ -x /usr/lib/php5/maxlifetime ] && [ -d /var/lib/php5 ] && find /var/lib/php5/ -depth -mindepth 1 -maxdepth 1 -type f -ignore_readdir_race -cmin +$(/usr/lib/php5/maxlifetime) ! -execdir fuser -s {} 2>/dev/null \; -delete)
Jan 7 09:09:01 lech /USR/SBIN/CRON[23990]: (root) CMD ( [ -x /usr/lib/php5/maxlifetime ] && [ -d /var/lib/php5 ] && find /var/lib/php5/ -depth -mindepth 1 -maxdepth 1 -type f -ignore_readdir_race -cmin +$(/usr/lib/php5/maxlifetime) ! -execdir fuser -s {} 2>/dev/null \; -delete)
Jan 7 09:17:01 lech /USR/SBIN/CRON[24012]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Jan 7 09:39:01 lech /USR/SBIN/CRON[24073]: (root) CMD ( [ -x /usr/lib/php5/maxlifetime ] && [ -d /var/lib/php5 ] && find /var/lib/php5/ -depth -mindepth 1 -maxdepth 1 -type f -ignore_readdir_race -cmin +$(/usr/lib/php5/maxlifetime) ! -execdir fuser -s {} 2>/dev/null \; -delete)
Jan 7 10:09:01 lech /USR/SBIN/CRON[24106]: (root) CMD ( [ -x /usr/lib/php5/maxlifetime ] && [ -d /var/lib/php5 ] && find /var/lib/php5/ -depth -mindepth 1 -maxdepth 1 -type f -ignore_readdir_race -cmin +$(/usr/lib/php5/maxlifetime) ! -execdir fuser -s {} 2>/dev/null \; -delete)
Jan 7 10:17:01 lech /USR/SBIN/CRON[24125]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Jan 7 10:27:22 lech kernel: [179543.381775] mysqld invoked oom-killer: gfp_mask=0x201da, order=0, oom_adj=0, oom_score_adj=0
Jan 7 10:27:23 lech kernel: [179543.381863] [<c0013e1c>] (unwind_backtrace+0x0/0xf0) from [<c008ca08>] (dump_header.isra.14+0x70/0x18c)
Jan 7 10:27:23 lech kernel: [179543.381904] [<c008ca08>] (dump_header.isra.14+0x70/0x18c) from [<c008cca8>] (oom_kill_process.constprop.19+0x68/0x27c)
Jan 7 10:27:23 lech kernel: [179543.381938] [<c008cca8>] (oom_kill_process.constprop.19+0x68/0x27c) from [<c008d2e4>] (out_of_memory+0x270/0x344)
Jan 7 10:27:23 lech kernel: [179543.381976] [<c008d2e4>] (out_of_memory+0x270/0x344) from [<c00903e8>] (__alloc_pages_nodemask+0x600/0x630)
Jan 7 10:27:23 lech kernel: [179543.382009] [<c00903e8>] (__alloc_pages_nodemask+0x600/0x630) from [<c008bd70>] (filemap_fault+0x250/0x4a8)
Jan 7 10:27:23 lech kernel: [179543.382055] [<c008bd70>] (filemap_fault+0x250/0x4a8) from [<c00a11f4>] (__do_fault+0x68/0x4a0)
Jan 7 10:27:23 lech kernel: [179543.382111] [<c00a11f4>] (__do_fault+0x68/0x4a0) from [<c00a3cf8>] (handle_pte_fault+0x74/0x784)
Jan 7 10:27:23 lech kernel: [179543.382146] [<c00a3cf8>] (handle_pte_fault+0x74/0x784) from [<c00a44b4>] (handle_mm_fault+0xac/0xec)
Jan 7 10:27:23 lech kernel: [179543.382196] [<c00a44b4>] (handle_mm_fault+0xac/0xec) from [<c037e0e8>] (do_page_fault+0x1c0/0x36c)
Jan 7 10:27:23 lech kernel: [179543.382232] [<c037e0e8>] (do_page_fault+0x1c0/0x36c) from [<c00083c0>] (do_PrefetchAbort+0x34/0x98)
Jan 7 10:27:23 lech kernel: [179543.382277] [<c00083c0>] (do_PrefetchAbort+0x34/0x98) from [<c037cd74>] (ret_from_exception+0x0/0x10)
Jan 7 10:27:23 lech kernel: [179543.382297] Exception stack(0xcb7c1fb0 to 0xcb7c1ff8)
Jan 7 10:27:23 lech kernel: [179543.382317] 1fa0: 51a8658c 00000000 00000002 00000000
Jan 7 10:27:23 lech kernel: [179543.382342] 1fc0: 0000119c 000011a8 51a864c0 00000000 00000000 51a98f18 40908c58 51a98898
Jan 7 10:27:23 lech kernel: [179543.382365] 1fe0: 00000000 4c0d0360 4029a8d8 40283ed4 60000010 ffffffff
Jan 7 10:27:23 lech kernel: [179543.382379] Mem-info:
Jan 7 10:27:23 lech kernel: [179543.382389] Normal per-cpu:
Jan 7 10:27:23 lech kernel: [179543.382403] CPU 0: hi: 90, btch: 15 usd: 21
Jan 7 10:27:23 lech kernel: [179543.382442] active_anon:20218 inactive_anon:20252 isolated_anon:0
Jan 7 10:27:23 lech kernel: [179543.382450] active_file:358 inactive_file:442 isolated_file:0
Jan 7 10:27:23 lech kernel: [179543.382458] unevictable:0 dirty:0 writeback:1 unstable:0
Jan 7 10:27:23 lech kernel: [179543.382465] free:2041 slab_reclaimable:531 slab_unreclaimable:1484
Jan 7 10:27:23 lech kernel: [179543.382473] mapped:310 shmem:4 pagetables:1026 bounce:0
Jan 7 10:27:23 lech kernel: [179543.382519] Normal free:8164kB min:8192kB low:10240kB high:12288kB active_anon:80872kB inactive_anon:81008kB active_file:1432kB inactive_file:1768kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:195072kB mlocked:0kB dirty:0kB writeback:4kB mapped:1240kB shmem:16kB slab_reclaimable:2124kB slab_unreclaimable:5936kB kernel_stack:1520kB pagetables:4104kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:4646 all_unreclaimable? yes
Jan 7 10:27:23 lech kernel: [179543.382564] lowmem_reserve[]: 0 0
Jan 7 10:27:23 lech kernel: [179543.382664] Normal: 169*4kB 0*8kB 0*16kB 6*32kB 12*64kB 5*128kB 1*256kB 3*512kB 0*1024kB 0*2048kB 1*4096kB = 8164kB
Jan 7 10:27:23 lech kernel: [179543.382712] 2284 total pagecache pages
Jan 7 10:27:23 lech kernel: [179543.382723] 1480 pages in swap cache
Jan 7 10:27:23 lech kernel: [179543.382735] Swap cache stats: add 1789621, delete 1788141, find 530835/687473
Jan 7 10:27:23 lech kernel: [179543.382748] Free swap = 0kB
Jan 7 10:27:23 lech kernel: [179543.382756] Total swap = 102396kB
Jan 7 10:27:23 lech kernel: [179543.393467] 49152 pages of RAM
Jan 7 10:27:23 lech kernel: [179543.393488] 2432 free pages
Jan 7 10:27:23 lech kernel: [179543.393497] 1877 reserved pages
Jan 7 10:27:23 lech kernel: [179543.393506] 2015 slab pages
Jan 7 10:27:23 lech kernel: [179543.393514] 12900 pages shared
Jan 7 10:27:23 lech kernel: [179543.393523] 1480 pages swap cached
Jan 7 10:27:23 lech kernel: [179543.393537] [ pid ] uid tgid total_vm rss cpu oom_adj oom_score_adj name
Jan 7 10:27:23 lech kernel: [179543.393578] [ 137] 0 137 694 22 0 -17 -1000 udevd
Jan 7 10:27:23 lech kernel: [179543.393603] [ 268] 0 268 693 23 0 -17 -1000 udevd
Jan 7 10:27:23 lech kernel: [179543.393626] [ 275] 0 275 693 22 0 -17 -1000 udevd
Jan 7 10:27:23 lech kernel: [179543.393649] [ 1337] 0 1337 436 9 0 -17 -1000 ifplugd
Jan 7 10:27:23 lech kernel: [179543.393673] [ 1377] 0 1377 436 9 0 -17 -1000 ifplugd
Jan 7 10:27:23 lech kernel: [179543.393696] [ 1632] 0 1632 6992 33 0 0 0 rsyslogd
Jan 7 10:27:23 lech kernel: [179543.393720] [ 1654] 0 1654 1223 44 0 -17 -1000 dhclient
Jan 7 10:27:23 lech kernel: [179543.393742] [ 1714] 106 1714 1134 0 0 0 0 shellinaboxd
Jan 7 10:27:23 lech kernel: [179543.393765] [ 1715] 0 1715 423 0 0 0 0 startpar
Jan 7 10:27:23 lech kernel: [179543.393837] [ 1718] 106 1718 1134 0 0 0 0 shellinaboxd
Jan 7 10:27:23 lech kernel: [179543.393865] [ 1791] 0 1791 1380 33 0 0 0 cron
Jan 7 10:27:23 lech kernel: [179543.393887] [ 1796] 104 1796 794 30 0 0 0 dbus-daemon
Jan 7 10:27:23 lech kernel: [179543.393914] [ 1874] 102 1874 1377 47 0 0 0 ntpd
Jan 7 10:27:23 lech kernel: [179543.393962] [ 2045] 0 2045 2464 37 0 0 0 proftpd
Jan 7 10:27:23 lech kernel: [179543.393989] [ 2219] 0 2219 1552 11 0 -17 -1000 sshd
Jan 7 10:27:23 lech kernel: [179543.394012] [ 2319] 1 2319 431 33 0 0 0 uptimed
Jan 7 10:27:23 lech kernel: [179543.394035] [ 2426] 0 2426 1072 0 0 0 0 getty
Jan 7 10:27:23 lech kernel: [179543.394058] [ 2427] 0 2427 1072 0 0 0 0 getty
Jan 7 10:27:23 lech kernel: [179543.394080] [ 2428] 0 2428 1072 0 0 0 0 getty
Jan 7 10:27:23 lech kernel: [179543.394103] [ 2429] 0 2429 1072 0 0 0 0 getty
Jan 7 10:27:23 lech kernel: [179543.394124] [ 2430] 0 2430 1072 0 0 0 0 getty
Jan 7 10:27:23 lech kernel: [179543.394146] [ 2431] 0 2431 1072 0 0 0 0 getty
Jan 7 10:27:23 lech kernel: [179543.394170] [ 2432] 0 2432 515 0 0 0 0 getty
Jan 7 10:27:23 lech kernel: [179543.394192] [ 2556] 0 2556 6629 31 0 0 0 console-kit-dae
Jan 7 10:27:23 lech kernel: [179543.394215] [ 2623] 0 2623 5571 22 0 0 0 polkitd
Jan 7 10:27:23 lech kernel: [179543.394238] [ 2642] 1000 2642 1560 35 0 0 0 screen
Jan 7 10:27:23 lech kernel: [179543.394260] [ 2643] 1000 2643 5200 157 0 0 0 irssi
Jan 7 10:27:23 lech kernel: [179543.394284] [ 3309] 0 3309 9072 550 0 0 0 apache2
Jan 7 10:27:23 lech kernel: [179543.394309] [18457] 0 18457 3480 50 0 0 0 nmbd
Jan 7 10:27:23 lech kernel: [179543.394330] [18460] 0 18460 5772 56 0 0 0 smbd
Jan 7 10:27:23 lech kernel: [179543.394353] [18470] 0 18470 5850 21 0 0 0 smbd
Jan 7 10:27:23 lech kernel: [179543.394375] [22972] 33 22972 13188 4131 0 0 0 apache2
Jan 7 10:27:23 lech kernel: [179543.394398] [22974] 33 22974 12932 3839 0 0 0 apache2
Jan 7 10:27:23 lech kernel: [179543.394422] [22975] 33 22975 13207 2263 0 0 0 apache2
Jan 7 10:27:23 lech kernel: [179543.394445] [22976] 33 22976 13199 2277 0 0 0 apache2
Jan 7 10:27:23 lech kernel: [179543.394467] [23025] 0 23025 438 27 0 0 0 mysqld_safe
Jan 7 10:27:23 lech kernel: [179543.394490] [23627] 107 23627 82305 1334 0 0 0 mysqld
Jan 7 10:27:23 lech kernel: [179543.394511] [23628] 0 23628 1261 29 0 0 0 logger
Jan 7 10:27:23 lech kernel: [179543.394536] [23716] 33 23716 13188 2744 0 0 0 apache2
Jan 7 10:27:23 lech kernel: [179543.394558] [23718] 33 23718 11654 3245 0 0 0 apache2
Jan 7 10:27:23 lech kernel: [179543.394581] [23719] 33 23719 13202 1954 0 0 0 apache2
Jan 7 10:27:23 lech kernel: [179543.394603] [23720] 33 23720 13194 3873 0 0 0 apache2
Jan 7 10:27:23 lech kernel: [179543.394626] [23721] 33 23721 13188 3739 0 0 0 apache2
Jan 7 10:27:23 lech kernel: [179543.394648] [23725] 33 23725 13188 2940 0 0 0 apache2
Jan 7 10:27:23 lech kernel: [179543.394672] [24203] 0 24203 2451 34 0 0 0 sshd
Jan 7 10:27:23 lech kernel: [179543.394695] [24210] 1000 24210 2451 69 0 0 0 sshd
Jan 7 10:27:23 lech kernel: [179543.394717] [24211] 1000 24211 1817 70 0 0 0 bash
Jan 7 10:27:23 lech kernel: [179543.394740] [24266] 33 24266 13188 3080 0 0 0 apache2
Jan 7 10:27:23 lech kernel: [179543.394762] [24267] 33 24267 12926 2922 0 0 0 apache2
Jan 7 10:27:23 lech kernel: [179543.394786] [24270] 33 24270 11387 2829 0 0 0 apache2
Jan 7 10:27:23 lech kernel: [179543.394809] [24313] 33 24313 11168 2726 0 0 0 apache2
Jan 7 10:27:23 lech kernel: [179543.394831] [24316] 33 24316 11168 2723 0 0 0 apache2
Jan 7 10:27:23 lech kernel: [179543.394854] [24319] 33 24319 9342 1161 0 0 0 apache2
Jan 7 10:27:23 lech kernel: [179543.394876] [24320] 33 24320 9082 524 0 0 0 apache2
Jan 7 10:27:23 lech kernel: [179543.394898] [24321] 33 24321 9078 501 0 0 0 apache2
Jan 7 10:27:23 lech kernel: [179543.394921] [24329] 33 24329 9078 501 0 0 0 apache2
Jan 7 10:27:23 lech kernel: [179543.394943] [24330] 33 24330 9078 501 0 0 0 apache2
Jan 7 10:27:23 lech kernel: [179543.394966] [24331] 33 24331 9078 501 0 0 0 apache2
Jan 7 10:27:23 lech kernel: [179543.394984] Out of memory: Kill process 23627 (mysqld) score 121 or sacrifice child
Jan 7 10:27:23 lech kernel: [179543.395016] Killed process 23627 (mysqld) total-vm:329220kB, anon-rss:5080kB, file-rss:256kB
Jan 7 10:29:02 lech kernel: [179643.772535] INFO: task kworker/u:2:24310 blocked for more than 120 seconds.
Jan 7 10:29:02 lech kernel: [179643.772561] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Jan 7 10:29:02 lech kernel: [179643.772578] kworker/u:2 D c037a204 0 24310 2 0x00000000
Jan 7 10:29:02 lech kernel: [179643.772646] [<c037a204>] (__schedule+0x2bc/0x568) from [<c029daec>] (__mmc_claim_host+0xa8/0x188)
Jan 7 10:29:02 lech kernel: [179643.772689] [<c029daec>] (__mmc_claim_host+0xa8/0x188) from [<c02a2e04>] (mmc_sd_detect+0x20/0x78)
Jan 7 10:29:02 lech kernel: [179643.772723] [<c02a2e04>] (mmc_sd_detect+0x20/0x78) from [<c029f8bc>] (mmc_rescan+0x1b4/0x314)
Jan 7 10:29:02 lech kernel: [179643.772769] [<c029f8bc>] (mmc_rescan+0x1b4/0x314) from [<c003da30>] (process_one_work+0x134/0x38c)
Jan 7 10:29:02 lech kernel: [179643.772805] [<c003da30>] (process_one_work+0x134/0x38c) from [<c003e4a4>] (worker_thread+0x1a0/0x354)
Jan 7 10:29:02 lech kernel: [179643.772844] [<c003e4a4>] (worker_thread+0x1a0/0x354) from [<c0042e3c>] (kthread+0x84/0x8c)
Jan 7 10:29:02 lech kernel: [179643.772886] [<c0042e3c>] (kthread+0x84/0x8c) from [<c000e930>] (kernel_thread_exit+0x0/0x8)
Jan 7 10:31:03 lech kernel: [179763.774449] INFO: task kworker/u:2:24310 blocked for more than 120 seconds.
Jan 7 10:31:04 lech kernel: [179763.774474] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Jan 7 10:31:04 lech kernel: [179763.774492] kworker/u:2 D c037a204 0 24310 2 0x00000000
Jan 7 10:31:04 lech kernel: [179763.774559] [<c037a204>] (__schedule+0x2bc/0x568) from [<c029daec>] (__mmc_claim_host+0xa8/0x188)
Jan 7 10:31:04 lech kernel: [179763.774604] [<c029daec>] (__mmc_claim_host+0xa8/0x188) from [<c02a2e04>] (mmc_sd_detect+0x20/0x78)
Jan 7 10:31:04 lech kernel: [179763.774639] [<c02a2e04>] (mmc_sd_detect+0x20/0x78) from [<c029f8bc>] (mmc_rescan+0x1b4/0x314)
Jan 7 10:31:04 lech kernel: [179763.774687] [<c029f8bc>] (mmc_rescan+0x1b4/0x314) from [<c003da30>] (process_one_work+0x134/0x38c)
Jan 7 10:31:04 lech kernel: [179763.774725] [<c003da30>] (process_one_work+0x134/0x38c) from [<c003e4a4>] (worker_thread+0x1a0/0x354)
Jan 7 10:31:04 lech kernel: [179763.774763] [<c003e4a4>] (worker_thread+0x1a0/0x354) from [<c0042e3c>] (kthread+0x84/0x8c)
Jan 7 10:31:04 lech kernel: [179763.774806] [<c0042e3c>] (kthread+0x84/0x8c) from [<c000e930>] (kernel_thread_exit+0x0/0x8)
Jan 7 10:33:02 lech kernel: [179883.776389] INFO: task kworker/u:2:24310 blocked for more than 120 seconds.
Jan 7 10:33:04 lech kernel: [179883.776415] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Jan 7 10:33:04 lech kernel: [179883.776431] kworker/u:2 D c037a204 0 24310 2 0x00000000
Jan 7 10:33:04 lech kernel: [179883.776515] [<c037a204>] (__schedule+0x2bc/0x568) from [<c029daec>] (__mmc_claim_host+0xa8/0x188)
Jan 7 10:33:04 lech kernel: [179883.776562] [<c029daec>] (__mmc_claim_host+0xa8/0x188) from [<c02a2e04>] (mmc_sd_detect+0x20/0x78)
Jan 7 10:33:04 lech kernel: [179883.776598] [<c02a2e04>] (mmc_sd_detect+0x20/0x78) from [<c029f8bc>] (mmc_rescan+0x1b4/0x314)
Jan 7 10:33:04 lech kernel: [179883.776647] [<c029f8bc>] (mmc_rescan+0x1b4/0x314) from [<c003da30>] (process_one_work+0x134/0x38c)
Jan 7 10:33:04 lech kernel: [179883.776710] [<c003da30>] (process_one_work+0x134/0x38c) from [<c003e4a4>] (worker_thread+0x1a0/0x354)
Jan 7 10:33:04 lech kernel: [179883.776752] [<c003e4a4>] (worker_thread+0x1a0/0x354) from [<c0042e3c>] (kthread+0x84/0x8c)
Jan 7 10:33:04 lech kernel: [179883.776795] [<c0042e3c>] (kthread+0x84/0x8c) from [<c000e930>] (kernel_thread_exit+0x0/0x8)
Jan 7 10:34:09 lech kernel: [179950.739465] ntpd invoked oom-killer: gfp_mask=0x201da, order=0, oom_adj=0, oom_score_adj=0
Jan 7 10:34:09 lech kernel: [179950.739552] [<c0013e1c>] (unwind_backtrace+0x0/0xf0) from [<c008ca08>] (dump_header.isra.14+0x70/0x18c)
Jan 7 10:34:09 lech kernel: [179950.739610] [<c008ca08>] (dump_header.isra.14+0x70/0x18c) from [<c008cca8>] (oom_kill_process.constprop.19+0x68/0x27c)
Jan 7 10:34:09 lech kernel: [179950.739647] [<c008cca8>] (oom_kill_process.constprop.19+0x68/0x27c) from [<c008d2e4>] (out_of_memory+0x270/0x344)
Jan 7 10:34:09 lech kernel: [179950.739686] [<c008d2e4>] (out_of_memory+0x270/0x344) from [<c00903e8>] (__alloc_pages_nodemask+0x600/0x630)
Jan 7 10:34:09 lech kernel: [179950.739721] [<c00903e8>] (__alloc_pages_nodemask+0x600/0x630) from [<c008bd70>] (filemap_fault+0x250/0x4a8)
Jan 7 10:34:09 lech kernel: [179950.739780] [<c008bd70>] (filemap_fault+0x250/0x4a8) from [<c00a11f4>] (__do_fault+0x68/0x4a0)
Jan 7 10:34:09 lech kernel: [179950.739820] [<c00a11f4>] (__do_fault+0x68/0x4a0) from [<c00a3cf8>] (handle_pte_fault+0x74/0x784)
Jan 7 10:34:09 lech kernel: [179950.739853] [<c00a3cf8>] (handle_pte_fault+0x74/0x784) from [<c00a44b4>] (handle_mm_fault+0xac/0xec)
Jan 7 10:34:09 lech kernel: [179950.739899] [<c00a44b4>] (handle_mm_fault+0xac/0xec) from [<c037e0e8>] (do_page_fault+0x1c0/0x36c)
Jan 7 10:34:09 lech kernel: [179950.739949] [<c037e0e8>] (do_page_fault+0x1c0/0x36c) from [<c00083c0>] (do_PrefetchAbort+0x34/0x98)
Jan 7 10:34:09 lech kernel: [179950.740027] [<c00083c0>] (do_PrefetchAbort+0x34/0x98) from [<c037cd74>] (ret_from_exception+0x0/0x10)
Jan 7 10:34:09 lech kernel: [179950.740049] Exception stack(0xc9507fb0 to 0xc9507ff8)
Jan 7 10:34:09 lech kernel: [179950.740108] 7fa0: 00000000 be948b70 00000010 0002bead
Jan 7 10:34:09 lech kernel: [179950.740136] 7fc0: 000cd904 000821a4 000cd8fc 00000000 000ccdd8 00000001 00000000 000ccdcc
Jan 7 10:34:09 lech kernel: [179950.740159] 7fe0: 00079074 be948b70 0004fd98 4018674c 20000010 ffffffff
Jan 7 10:34:09 lech kernel: [179950.740174] Mem-info:
Jan 7 10:34:09 lech kernel: [179950.740184] Normal per-cpu:
Jan 7 10:34:09 lech kernel: [179950.740198] CPU 0: hi: 90, btch: 15 usd: 27
Jan 7 10:34:09 lech kernel: [179950.740226] active_anon:20116 inactive_anon:20175 isolated_anon:0
Jan 7 10:34:09 lech kernel: [179950.740234] active_file:342 inactive_file:444 isolated_file:0
Jan 7 10:34:09 lech kernel: [179950.740241] unevictable:0 dirty:0 writeback:0 unstable:0
Jan 7 10:34:09 lech kernel: [179950.740248] free:2040 slab_reclaimable:528 slab_unreclaimable:1597
Jan 7 10:34:09 lech kernel: [179950.740257] mapped:310 shmem:7 pagetables:1110 bounce:0
Jan 7 10:34:09 lech kernel: [179950.740312] Normal free:8160kB min:8192kB low:10240kB high:12288kB active_anon:80464kB inactive_anon:80700kB active_file:1368kB inactive_file:1776kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:195072kB mlocked:0kB dirty:0kB writeback:0kB mapped:1240kB shmem:28kB slab_reclaimable:2112kB slab_unreclaimable:6388kB kernel_stack:1344kB pagetables:4440kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:4493 all_unreclaimable? yes
Jan 7 10:34:09 lech kernel: [179950.740359] lowmem_reserve[]: 0 0
Jan 7 10:34:09 lech kernel: [179950.740372] Normal: 180*4kB 34*8kB 4*16kB 4*32kB 7*64kB 5*128kB 1*256kB 3*512kB 0*1024kB 0*2048kB 1*4096kB = 8160kB
Jan 7 10:34:09 lech kernel: [179950.740429] 6046 total pagecache pages
Jan 7 10:34:09 lech kernel: [179950.740442] 5253 pages in swap cache
Jan 7 10:34:09 lech kernel: [179950.740455] Swap cache stats: add 1903076, delete 1897823, find 546086/714007
Jan 7 10:34:09 lech kernel: [179950.740468] Free swap = 0kB
Jan 7 10:34:09 lech kernel: [179950.740476] Total swap = 102396kB
Jan 7 10:34:09 lech kernel: [179950.751432] 49152 pages of RAM
Jan 7 10:34:09 lech kernel: [179950.751455] 2442 free pages
Jan 7 10:34:09 lech kernel: [179950.751464] 1877 reserved pages
Jan 7 10:34:09 lech kernel: [179950.751472] 2125 slab pages
Jan 7 10:34:09 lech kernel: [179950.751481] 4991 pages shared
Jan 7 10:34:09 lech kernel: [179950.751490] 5253 pages swap cached
Jan 7 10:34:09 lech kernel: [179950.751500] [ pid ] uid tgid total_vm rss cpu oom_adj oom_score_adj name
Jan 7 10:34:09 lech kernel: [179950.751541] [ 137] 0 137 694 5 0 -17 -1000 udevd
Jan 7 10:34:09 lech kernel: [179950.751563] [ 268] 0 268 693 5 0 -17 -1000 udevd
Jan 7 10:34:09 lech kernel: [179950.751587] [ 275] 0 275 693 5 0 -17 -1000 udevd
Jan 7 10:34:09 lech kernel: [179950.751610] [ 1337] 0 1337 436 11 0 -17 -1000 ifplugd
Jan 7 10:34:09 lech kernel: [179950.751632] [ 1377] 0 1377 436 11 0 -17 -1000 ifplugd
Jan 7 10:34:09 lech kernel: [179950.751654] [ 1632] 0 1632 6992 73 0 0 0 rsyslogd
Jan 7 10:34:09 lech kernel: [179950.751677] [ 1654] 0 1654 1223 48 0 -17 -1000 dhclient
Jan 7 10:34:09 lech kernel: [179950.751700] [ 1714] 106 1714 1134 1 0 0 0 shellinaboxd
Jan 7 10:34:09 lech kernel: [179950.751722] [ 1715] 0 1715 423 1 0 0 0 startpar
Jan 7 10:34:09 lech kernel: [179950.751744] [ 1718] 106 1718 1134 1 0 0 0 shellinaboxd
Jan 7 10:34:09 lech kernel: [179950.751767] [ 1791] 0 1791 1380 30 0 0 0 cron
Jan 7 10:34:09 lech kernel: [179950.751788] [ 1796] 104 1796 794 7 0 0 0 dbus-daemon
Jan 7 10:34:09 lech kernel: [179950.751811] [ 1874] 102 1874 1377 31 0 0 0 ntpd
Jan 7 10:34:09 lech kernel: [179950.751833] [ 2045] 0 2045 2464 34 0 0 0 proftpd
Jan 7 10:34:09 lech kernel: [179950.751856] [ 2219] 0 2219 1552 31 0 -17 -1000 sshd
Jan 7 10:34:09 lech kernel: [179950.751877] [ 2319] 1 2319 431 20 0 0 0 uptimed
Jan 7 10:34:09 lech kernel: [179950.751899] [ 2426] 0 2426 1072 1 0 0 0 getty
Jan 7 10:34:09 lech kernel: [179950.751921] [ 2427] 0 2427 1072 0 0 0 0 getty
Jan 7 10:34:09 lech kernel: [179950.751944] [ 2428] 0 2428 1072 0 0 0 0 getty
Jan 7 10:34:09 lech kernel: [179950.751966] [ 2429] 0 2429 1072 0 0 0 0 getty
Jan 7 10:34:09 lech kernel: [179950.751988] [ 2430] 0 2430 1072 0 0 0 0 getty
Jan 7 10:34:09 lech kernel: [179950.752010] [ 2431] 0 2431 1072 0 0 0 0 getty
Jan 7 10:34:09 lech kernel: [179950.752032] [ 2432] 0 2432 515 0 0 0 0 getty
Jan 7 10:34:09 lech kernel: [179950.752055] [ 2556] 0 2556 6629 8 0 0 0 console-kit-dae
Jan 7 10:34:09 lech kernel: [179950.752079] [ 2623] 0 2623 5571 5 0 0 0 polkitd
Jan 7 10:34:09 lech kernel: [179950.752101] [ 2642] 1000 2642 1560 21 0 0 0 screen
Jan 7 10:34:09 lech kernel: [179950.752124] [ 2643] 1000 2643 5200 110 0 0 0 irssi
Jan 7 10:34:09 lech kernel: [179950.752145] [ 3309] 0 3309 9072 150 0 0 0 apache2
Jan 7 10:34:09 lech kernel: [179950.752170] [18457] 0 18457 3480 39 0 0 0 nmbd
Jan 7 10:34:09 lech kernel: [179950.752193] [18460] 0 18460 5772 40 0 0 0 smbd
Jan 7 10:34:09 lech kernel: [179950.752215] [18470] 0 18470 5850 6 0 0 0 smbd
Jan 7 10:34:09 lech kernel: [179950.752237] [22972] 33 22972 13188 1384 0 0 0 apache2
Jan 7 10:34:09 lech kernel: [179950.752260] [22974] 33 22974 12932 2038 0 0 0 apache2
Jan 7 10:34:09 lech kernel: [179950.752282] [22975] 33 22975 13196 3068 0 0 0 apache2
Jan 7 10:34:09 lech kernel: [179950.752304] [22976] 33 22976 13188 3034 0 0 0 apache2
Jan 7 10:34:09 lech kernel: [179950.752329] [23025] 0 23025 438 11 0 0 0 mysqld_safe
Jan 7 10:34:09 lech kernel: [179950.752352] [23716] 33 23716 13188 2185 0 0 0 apache2
Jan 7 10:34:09 lech kernel: [179950.752375] [23718] 33 23718 13190 3551 0 0 0 apache2
Jan 7 10:34:09 lech kernel: [179950.752397] [23719] 33 23719 13201 3430 0 0 0 apache2
Jan 7 10:34:09 lech kernel: [179950.752420] [23721] 33 23721 13194 1945 0 0 0 apache2
Jan 7 10:34:09 lech kernel: [179950.752443] [23725] 33 23725 13188 2206 0 0 0 apache2
Jan 7 10:34:09 lech kernel: [179950.752466] [24203] 0 24203 2451 10 0 0 0 sshd
Jan 7 10:34:09 lech kernel: [179950.752489] [24210] 1000 24210 2451 51 0 0 0 sshd
Jan 7 10:34:09 lech kernel: [179950.752511] [24211] 1000 24211 1817 108 0 0 0 bash
Jan 7 10:34:09 lech kernel: [179950.752534] [24266] 33 24266 13188 1834 0 0 0 apache2
Jan 7 10:34:09 lech kernel: [179950.752556] [24267] 33 24267 13188 1558 0 0 0 apache2
Jan 7 10:34:09 lech kernel: [179950.752581] [24270] 33 24270 13180 3306 0 0 0 apache2
Jan 7 10:34:09 lech kernel: [179950.752604] [24313] 33 24313 13180 3411 0 0 0 apache2
Jan 7 10:34:09 lech kernel: [179950.752627] [24316] 33 24316 13180 3388 0 0 0 apache2
Jan 7 10:34:09 lech kernel: [179950.752649] [24319] 33 24319 10096 448 0 0 0 apache2
Jan 7 10:34:09 lech kernel: [179950.752671] [24320] 33 24320 9350 214 0 0 0 apache2
Jan 7 10:34:09 lech kernel: [179950.752694] [24321] 33 24321 9072 293 0 0 0 apache2
Jan 7 10:34:09 lech kernel: [179950.752717] [24329] 33 24329 9086 166 0 0 0 apache2
Jan 7 10:34:09 lech kernel: [179950.752739] [24330] 33 24330 9072 291 0 0 0 apache2
Jan 7 10:34:09 lech kernel: [179950.752761] [24331] 33 24331 9090 252 0 0 0 apache2
Jan 7 10:34:09 lech kernel: [179950.752783] [24338] 33 24338 9348 209 0 0 0 apache2
Jan 7 10:34:09 lech kernel: [179950.752806] [24339] 33 24339 9086 159 0 0 0 apache2
Jan 7 10:34:09 lech kernel: [179950.752829] [24356] 0 24356 1552 124 0 0 0 sshd
Jan 7 10:34:09 lech kernel: [179950.752851] [24361] 0 24361 3368 86 0 0 0 mysqld
Jan 7 10:34:09 lech kernel: [179950.752874] [24363] 0 24363 1261 8 0 0 0 logger
Jan 7 10:34:09 lech kernel: [179950.752896] [24398] 0 24398 1552 139 0 0 0 sshd
Jan 7 10:34:09 lech kernel: [179950.752918] [24401] 33 24401 9072 291 0 0 0 apache2
Jan 7 10:34:09 lech kernel: [179950.752942] [24407] 33 24407 9072 290 0 0 0 apache2
Jan 7 10:34:09 lech kernel: [179950.752965] [24414] 33 24414 438 41 0 0 0 sh
Jan 7 10:34:09 lech kernel: [179950.752986] [24415] 33 24415 749 120 0 0 0 top
Jan 7 10:34:09 lech kernel: [179950.753009] [24422] 33 24422 438 48 0 0 0 sh
Jan 7 10:34:09 lech kernel: [179950.753030] [24423] 33 24423 105 33 0 0 0 uprecords
Jan 7 10:34:09 lech kernel: [179950.753051] Out of memory: Kill process 22975 (apache2) score 67 or sacrifice child
Jan 7 10:34:09 lech kernel: [179950.753071] Killed process 22975 (apache2) total-vm:52784kB, anon-rss:11684kB, file-rss:588kB
Jan 7 10:35:02 lech kernel: [180003.778250] INFO: task kworker/u:2:24310 blocked for more than 120 seconds.
Jan 7 10:35:02 lech kernel: [180003.778276] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Jan 7 10:35:02 lech kernel: [180003.778292] kworker/u:2 D c037a204 0 24310 2 0x00000000
Jan 7 10:35:02 lech kernel: [180003.778362] [<c037a204>] (__schedule+0x2bc/0x568) from [<c029daec>] (__mmc_claim_host+0xa8/0x188)
Jan 7 10:35:02 lech kernel: [180003.778405] [<c029daec>] (__mmc_claim_host+0xa8/0x188) from [<c02a2e04>] (mmc_sd_detect+0x20/0x78)
Jan 7 10:35:02 lech kernel: [180003.778440] [<c02a2e04>] (mmc_sd_detect+0x20/0x78) from [<c029f8bc>] (mmc_rescan+0x1b4/0x314)
Jan 7 10:35:02 lech kernel: [180003.778486] [<c029f8bc>] (mmc_rescan+0x1b4/0x314) from [<c003da30>] (process_one_work+0x134/0x38c)
Jan 7 10:35:02 lech kernel: [180003.778560] [<c003da30>] (process_one_work+0x134/0x38c) from [<c003e4a4>] (worker_thread+0x1a0/0x354)
Jan 7 10:35:02 lech kernel: [180003.778606] [<c003e4a4>] (worker_thread+0x1a0/0x354) from [<c0042e3c>] (kthread+0x84/0x8c)
Jan 7 10:35:02 lech kernel: [180003.778674] [<c0042e3c>] (kthread+0x84/0x8c) from [<c000e930>] (kernel_thread_exit+0x0/0x8)
Jan 7 10:39:01 lech /USR/SBIN/CRON[24543]: (root) CMD ( [ -x /usr/lib/php5/maxlifetime ] && [ -d /var/lib/php5 ] && find /var/lib/php5/ -depth -mindepth 1 -maxdepth 1 -type f -ignore_readdir_race -cmin +$(/usr/lib/php5/maxlifetime) ! -execdir fuser -s {} 2>/dev/null \; -delete)
That doesn't give me much info but I hope that you can get something out of it.
I think those are all logs from the reinstalation of mysql untill it dies.
