AndrewPayton
Chromium autostart in fullscreen
Fri Sep 04, 2020 9:53 am
The autostart kiosk command works great, but does anyone know how to exit back to the Raspbian desktop? You can Alt-F4 to close the Chromium full-screen browser in Kiosk mode, but it doesn't take you to the desktop--it's just a black screen. The only way to get back to a Raspbian desktop is to right click on the black screen to start a Terminal emulation and then change the autostart filename so it doesn't run the kiosk mode on reboot. Would be great if you could just exit to the desktop. Any help for this NOOB is appreciated.
klricks
Re: Chromium autostart in fullscreen
Fri Sep 04, 2020 2:40 pm
Make sure your autostart file contains these 2 lines:
@lxpanel --profile LXDE-pi
@pcmanfm --desktop --profile LXDE-pi
Botspot
Fri Sep 04, 2020 4:45 pm
Yeah that's my guess as well.
Raspberry Pi OS Buster uses a global autostart file - /etc/xdg/lxsession/LXDE-pi/autostart, but Raspbian Stretch used a user-specific file, located at /home/pi/.config/lxsession/LXDE-pi/autostart.
If the OP found an outdated tutorial, it very likely told them to edit .config/lxsession/LXDE-pi/autostart. The OP must have created that file, as it doesn't exist by default.
When .config/lxsession/LXDE-pi/autostart exists, LXDE ignores the global autostart file.
So if you delete .config/lxsession/LXDE-pi/autostart, LXDE will again use the global one once again.
To the OP:
  • Either make your autostart changes directly to /etc/xdg/lxsession/LXDE-pi/autostart, and don't create .config/lxsession/LXDE-pi/autostart, or...
  • ...Copy the contents of /etc/xdg/lxsession/LXDE-pi/autostart into .config/lxsession/LXDE-pi/autostart so the desktop will launch behind Chromium like it's supposed to.
Want to run Minecraft Java on your RPi? Easiest way is with Pi-Apps - just click Install.
https://github.com/Botspot/pi-apps
Pi-Apps also includes Zoom, Visual Studio, Tor browser, Windows 10 theme, and 33 more.
Over 50,000 users!
GonzoGonzoGonzo
Sat Oct 17, 2020 7:15 am
This is incredibly helpful and I haven't managed to find it elsewhere - thanks for sharing this!
Botspot
Sat Oct 17, 2020 12:43 pm
Thanks! :)
BTW nearly al Linux config files are set up this way - you have a global config file usually located in /etc, and if you want to make changes to it but don't have root privileges, you copy the global to the personal and make your changes there.
Over 50,000 users!
