ThanksDougieLawson wrote: ↑Sun Aug 30, 2020 8:05 pmIf you use the imager (or Balena Etcher) then there is no pre-formatting needed, the image includes the file system format. Pre-formatting to FAT32 is only needed for NOOBS.
ThanksHawaiianPi wrote: ↑Sun Aug 30, 2020 8:00 pmYes, images can be written to any size cards without worrying about previous file systems or formatting.
Just use the Raspberry Pi Imager or Etcher to write and verify your cards (you will need an SDXC compatible card reader to write larger cards as well).
EDIT
I have tested cards as larger as 400GB on Raspberry Pi computers.
