alfiesty
put main stuff on hd
Sat Jan 05, 2013 3:56 am
I understand it is possible to boot to SD but have system on USB hard drive. I am a noob, and would like to know how to do this.
Jim
8000 feet(2438M) above the average!
Re: put main stuff on hd
Sat Jan 05, 2013 6:36 am
It's fairly easy to do, and quite common. There are a number of advantages to doing this.
Note, it is very important that your USB disk has its own PSU - the Pi can't supply enough to run without blowing its fuse.
There are a couple of ways to do it on the thread here: http://www.raspberrypi.org/phpBB3/viewt ... =63&t=6565 along with some links to other threads with more details.
It basically boils down to:
1) Create a suitable partition on your USB HD (ext4 is good)
2) Copy the contents of the "/" partition onto the disk.
3) Edit /boot/cmdline.txt to say root=/dev/sda1 (assuming you only created on partition).
4. Reboot
You will still need your SD card with the /boot partition on.
Mobius
Sat Jan 05, 2013 2:53 pm
One way to get around the power issue is to use a USB flash drive instead of a hard drive. You can get decent 32GB drives for less than $20 US. Not sure what all you would want to store that would require huge amounts of disk space.
