unityco
Order of Install? PiVPN, VNC, Plex, PiHole...
Tue Aug 11, 2020 11:01 pm
Hello! I've got a brand-new Pi4 that I would like to setup to run 1-PiVPN, 2-VNC, 3-Plex, 4-PiHole, 5-FlexTV, in order of importance. I just tried adding Flex as the last service and it broke everything, so I reformatted and want to start again. Is one order better than another? Can all these services co-exist at the same time?
Thanks!
bassamanator
Re: Order of Install? PiVPN, VNC, Plex, PiHole...
Wed Aug 12, 2020 2:00 am
VNC comes preinstalled with rpiOS. Just enable it.
I remember when I installed pivpn, it asked me at some point if I had pihole installed, so I would do pihole then pivpn.
Everything else can be installed afterwards.
| Raspberry Pi 4-8GB | 2.0GHz | over_voltage@5 |
| Raspberry Pi OS 32bit |
| https://github.com/bassamanator/raspberrypi-scripts |
Penta
Tue Jan 12, 2021 6:49 am
Hi, I know it's an old-ish topic, but I just encountered a similar issue. VNC was activated and was working fine, and after installing PiVPN it doesn't connect anymore. Any idea why? Maybe install PiVPN first and activate VNC after?
