External USB Hard drive mounted, partioned but not listed (was: How to check how much free space is left on external HD)
Posted: Wed Aug 05, 2020 8:05 pm
by DarKOrange
Hi all,
I was trying to check how much space was left on my external drive when I realised that it was not listed. How to fix that?
Thank you for your help!
Laurent
Re: How to check how much free space is left on external USB Hard drive
Posted: Wed Aug 05, 2020 8:15 pm
by trejan
Run "df -h"
Posted: Thu Aug 06, 2020 6:41 am
by DarKOrange
I did that but the USB drive partition is not listed
Sys. de fichiers Taille Utilisé Dispo Uti% Monté sur
/dev/root 29G 2,2G 26G 8% /
devtmpfs 184M 0 184M 0% /dev
tmpfs 216M 0 216M 0% /dev/shm
tmpfs 216M 22M 194M 11% /run
tmpfs 5,0M 4,0K 5,0M 1% /run/lock
tmpfs 216M 0 216M 0% /sys/fs/cgroup
/dev/mmcblk0p1 253M 55M 198M 22% /boot
tmpfs 44M 0 44M 0% /run/user/1000
The mounted partition is on /dev/sda
Disk /dev/sda: 58,6 GiB, 62914560000 bytes, 122880000 sectors
Disk model: STORAGE DEVICE
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x55dd0322
Posted: Thu Aug 06, 2020 8:51 am
by rpdom
From what I can see, that drive is not partitioned or formatted.
I would expect output like
Disk /dev/sdb: 55.9 GiB, 60022480384 bytes, 117231407 sectors
Disk model: Expansion
I/O size (minimum/optimal): 512 bytes / 33553920 bytes
Disklabel type: dos
Disk identifier: 0xdae8205d
Device     Boot Start       End   Sectors  Size Id Type
/dev/sdb1        2048 117229567 117227520 55.9G 83 Linux
Some details will differ from yours. Mine is sdb in this case, not sda and the size is slightly different.
Posted: Thu Aug 06, 2020 9:45 am
by DarKOrange
Thank you for your answer. It is partioned and formatted, I can access it with Filezilla and read/write files.
/dev/sda1 2048 122879999 122877952 58,6G 83 Linux
Posted: Thu Aug 06, 2020 9:56 am
by FTrevorGowen
Hmm. I normally use FileZilla for SFTP to networked drives (or other computers) USB drives are usually auto-mounted via the file manager and appear under the /media directory.
Trev.
Re: External USB Hard drive mounted, partioned but not listed (was: How to check how much free space is left on external
Posted: Thu Aug 06, 2020 10:02 am
by DarKOrange
I am using FileZilla to access a remote Pi files, and I am using ssh for admin/coding. The drive is not present in the /media folder but in the /mnt folder
Posted: Thu Aug 06, 2020 10:20 am
by LTolledo
please post output of
lsusb
lsblk
sudo blkid
Posted: Thu Aug 06, 2020 10:28 am
by DarKOrange
lsusb
lsblk
sudo blkid
Thank you. Here it is:
lsusb:
Bus 001 Device 002: ID 1f75:0918 Innostor Technology Corporation
lsblk:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 1 58,6G 0 disk
└─sda1 8:1 1 58,6G 0 part
mmcblk0 179:0 0 29,2G 0 disk
├─mmcblk0p1 179:1 0 256M 0 part /boot
└─mmcblk0p2 179:2 0 28,9G 0 part /
sudo blkid:
/dev/mmcblk0p1: LABEL_FATBOOT="boot" LABEL="boot" UUID="592B-C92C" TYPE="vfat" PARTUUID="841b483c-01"
/dev/mmcblk0p2: LABEL="rootfs" UUID="706944a6-7d0f-4a45-9f8c-7fb07375e9f7" TYPE="ext4" PARTUUID="841b483c-02"
/dev/sda1: UUID="1eee1c8d-3d8d-437f-87c2-3fe930d4b974" TYPE="ext2" PARTUUID="55dd0322-01"
/dev/mmcblk0: PTUUID="841b483c" PTTYPE="dos"
Posted: Thu Aug 06, 2020 10:58 am
by LTolledo
DarKOrange wrote: /dev/sda1: UUID="1eee1c8d-3d8d-437f-87c2-3fe930d4b974" TYPE="ext2" PARTUUID="55dd0322-01"
this confirms your drive is formatted as EXT2
first let make a mount point for your external USB hard drive
sudo mkdir /mnt/exHDD
then lets mount it properly with an entry in /etc/fstab
UUID=1eee1c8d-3d8d-437f-87c2-3fe930d4b974  /mnt/exHDD  ext2  defaults,nofail,noatime  0  1
reboot and then check again using
df -h
Posted: Thu Aug 06, 2020 11:30 pm
by DarKOrange
df -h
Thank you for your answer, I followed your directions but still no luck :( The external storage has disappeared from the following commands but I can still browse the content of the USB stick but through the old mount point, the new one (exHDD) is empty.
New output:
df -h
/dev/root 29G 2,1G 26G 8% /
tmpfs 216M 3,1M 213M 2% /run
lsusb
lsblk
sudo blkid
Posted: Fri Aug 07, 2020 7:08 am
by diogen151
Innostor chipset for USB drive?
Are you using RPi 4b and USB 3.0 ?
Innostor chipset is not well prooven in this combination like ASMEDIA ASM chipset.
Try with this:
sudo dmesg -C
..then connect that USB drive, and post output from this command:
sudo dmesg -T
Hope this will give some more information.
Posted: Fri Aug 07, 2020 7:25 am
by DarKOrange
Try with this:
sudo dmesg -C
sudo dmesg -T
Hi, thank you for your answer. I should have mentioned it: it is a Raspberry Pi 3 Model A Plus Rev 1.0
Unfortunately I don't have physical access to this Rpi which is hundreds of kilometers from me and can't plug/unplug the USK stick.
The output of the above commands is empty.
Posted: Fri Aug 07, 2020 9:53 am
by nliviu
What is the old mount point?
You can run mount to list all the mount points.
Posted: Fri Aug 07, 2020 10:00 am
by DarKOrange
The old mount point is named USBStick
The output of the mount command doesn't list it, that is very weird since I can still browse the USB key...
/dev/mmcblk0p2 on / type ext4 (rw,noatime)
devtmpfs on /dev type devtmpfs (rw,relatime,size=187428k,nr_inodes=46857,mode=755)
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
proc on /proc type proc (rw,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,nodev,mode=755)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
cgroup2 on /sys/fs/cgroup/unified type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,name=systemd)
none on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)
cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
cgroup on /sys/fs/cgroup/net_cls type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls)
cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=32,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)
mqueue on /dev/mqueue type mqueue (rw,relatime)
sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
configfs on /sys/kernel/config type configfs (rw,relatime)
/dev/mmcblk0p1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro)
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=44140k,mode=700,uid=1000,gid=1000)
Posted: Fri Aug 07, 2020 10:13 am
by nliviu
It looks like it's not mounted.
A mount point has a full path, something like "/mnt/USBStick".
The entry in the mount list should read something like
/dev/sda1 on /mnt/USBStick ...
If you can see it with filezilla, you can see it in the ssh session too (using the same path).
Posted: Fri Aug 07, 2020 12:42 pm
by DarKOrange
Yes it is there with ssh too: /mnt/USBStick
I can browse it but none of the command lines to get info are seeing it.
Posted: Fri Aug 07, 2020 1:28 pm
by FTrevorGowen
OOC, what does FileZilla report about the drive. I can't check a "remote server" at the moment but for a similar local drive (128GB SSD + USB-to-SATA adapter)I get this:
Trev.
Posted: Fri Aug 07, 2020 1:31 pm
by nliviu
My bet is that the directory /mnt/USBStick is populated with files from the sd, not from the external drive which is not mounted.
Try to unmount it
sudo umount /mnt/USBStick
If the result is "umount: /mnt/USBStick: not mounted.", you can try to mount it from the command line, assuming /mnt/exHDD still exists
sudo mount -t ext2 /dev/sda1 /mnt/exHDD
Posted: Fri Aug 07, 2020 2:23 pm
by DarKOrange
Try to unmount it
I think you nailed it!
I copied files to the USBStick and the space on the sd card decreased...
Right now I can't mount sda because it is no longer available, I am trying to have someone unplug and replug the USB key
Posted: Fri Aug 07, 2020 2:33 pm
by nliviu
Unmount from /mnt/exHDD and mount on /mnt/USBStick
sudo umount /mnt/exHDD
sudo mount -t ext2 /dev/sda1 /mnt/USBStick
Posted: Fri Aug 07, 2020 3:01 pm
by DarKOrange
Thank you. Following previous manipulations (below) the USB key is no longer seen by the system,
df -h
so I can't mount it. I tried to reboot but I'll need someone to physically remove and replug the USB key into the raspberry Pi. Unless you know another way to access it again.
lsusb
USB key no longer listed
Posted: Sat Aug 08, 2020 7:39 am
by DarKOrange
Problem solved! I got someone to remove and replug the key, I was then able to mount the USB key in the exHDD folder, it is now listed with the df -h command !
Thank you :D :D :D and thank to all !
Have a nice day,
Laurent
