mccla5214
Panel Bar being covered by NONE MAXIMIZED screens
Sun Jul 26, 2020 12:01 am
I have run into an issue on the PI4 that I cannot find a work around for. The program that I am running has an issue that when it crashes the un-maximized window size is wider than the normal PI desktop and will cover up the panel bar at the bottom so I cannot get to anything. I have to power cycle the PI4 to get access to the panel bar. The settings are correct for reserving space for the panel bar when a window is maximized but if you take a normal window and drag it to the bottom of the screen you can see it cover the panel up. Now imaging dragging that normal screen over to the left, stretch it in width to make it wider, then drag the screen back to the center. Now the entire bar at the bottom is covered up. Since the program that is causing the issue has crashed it cannot be drug out of the way.
Is there any way to get the panel back on top in a situation like this. In windows I always just checked Taskbar Always on Top and it was not an issue, but this one is throwing me.
Thanks,
Mike
