relindwto6
Questions about programming on the Raspberry Pi [spam]
Thu Jul 23, 2020 5:26 pm
Hello everyone, i was wondering what would be the best programming language for the raspberry pi.
I am a software developer which works with C#, so I got that going for me.
I also already finished quite a big project with C# and Windows IOT on the Raspberry Pi but I wondered if there are better languages / possibilities out there.
My question, what is the favourite language on the Raspberry Pi?
What is the most beneficial language on the Pi because it can do the most (Fast, UI)?
I would like to do a little "homeautomation project" where I get myself a Pi with a 7" Touch Display.
So I would definetly need a possibility to create a nice UI (like UWP).
This is something I would like to programm on my own, even if there are some solutions out there.
Also I am thinking about doing this as a web service which then is displayed on the Raspberry Pi.
What would you recommend me to use as the programming language?
Thanks for your feedback and answers.
hitsware
Re: Questions about programming on the Raspberry Pi
Thu Jul 23, 2020 6:09 pm
Call me old fashioned .
I like this one :
https://basic256.org/ ( available in repository )
BUT
The de rigueur seems to be Python
( which comes already installed )
http://www.hitswares.com/
FTrevorGowen
Thu Jul 23, 2020 6:43 pm
I like this one :
BUT
Historically, "Python" is the "root" of Pi in "Raspberry Pi" and, AIUI, the "main" language used "educationally". Old (Ancient?) scientific programmer's like myself may prefer 'C' but Linux supports quite a few others. TBH, I suggest use the language(s) you're most comfortable with and which support any specific GPIO-related tasks you need. IDE's exist too (I'm not a "big fan" as I don't like "hidden" build/compilation/linkage actions and prefer the GNU autotools etc. - partially because, prior to my retirement, I contributed to and maintained a complex combined Fortran/'C' suite of programs)
Trev.
Still running Raspbian Jessie or Stretch on some older Pi's (an A, B1, 2xB2, B+, P2B, 3xP0, P0W, 2xP3A+, P3B+, P3B, B+, and a A+) but Buster on the P4B's & P400. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
jahboater
Thu Jul 23, 2020 6:55 pm
Yes. Look at the number of posts in the "programming" part of this forum and you will see that Python is by far the most popular (or at least the most discussed) followed by C/C++.
The Raspberry Pi OS is Linux which is written in C, as are most of the surrounding tools. So C is the language that can best be described as "native" to the Pi, and C is also the fastest. If you need help on a C library function for example, the system manual pages will cover them all.
Python and C (and C++) are both pre-installed (that is, included within the OS) so they work out of the box.
Python and C have great access to the GPIO (much of the code that directly accesses the GPIO is written in C of course).
See this superb (included) library which has C and Python interfaces:-
http://abyz.me.uk/rpi/pigpio/
Having said that, there are many many languages available, so choose whichever you like most!
My personal choice is Python for interpreted and C for compiled.
Pi4 8GB (Raspberry Pi OS 64-bit), Pi4 4GB, Pi1 Rev 1 256MB, Pi Zero
B.Goode
Thu Jul 23, 2020 7:02 pm
It's just a computer. A physically small, low power requirement, cheap to buy, computer.
It can be programmed using just about any computer programming language you have heard of. And probably also quite a few you haven't. The fact that you have managed to use c# is itself evidence of that.
A lot of people gravitate towards Python for ease of prototyping/development and range of pre-existing libraries. Including UIs. And web services..
But no recommendation from me. Use what works for you.
There have been many such discussions in the past. They are usually inconclusive.
jahboater
Thu Jul 23, 2020 7:12 pm
It also runs Linux (the "official" OS called Raspberry Pi OS is based on Debian Linux).
Which means a wide range of high quality, and free, compilers and interpreters are either pre-installed or are mostly a simple "apt install" away.
neilgl
Thu Jul 23, 2020 8:37 pm
I would go with Perl
LTolledo
Thu Jul 23, 2020 9:13 pm
for RPi programming I use python via IDLE (seems to take fewer resources than Mu)
for programming arduinos (and arduino compatible microcontrollers) using RPi, I use Arduino IDE....
Some people be like:
jahboater
Thu Jul 23, 2020 10:05 pm
I believe that Thonny is the "official" RPT supported Python IDE.
(Included in Raspberry Pi OS)
knute
Fri Jul 24, 2020 2:46 pm
If you are used to C# I would just use Java. But then I would use Java anyway :-).
mahjongg
Mon Jul 27, 2020 9:42 am
OP was a spammer, deleted several post edited in hidden spamlinks and retired the spammer
on request I will not delete this thread
